Hillbilly Brake concern
F
Fyathyrio
240
662
There is a cool Youtube channel, called Lock Picking Lawyer, where dude tears apart, picks, and details the flaws of many locks in quick videos, mostly under 5 min. A lock earning his respect is fairly rare. Once you watch a few vids there, you will never buy anything Master Lock branded again. If you are concerned about any item rolling away, he recommends this lock, along with this chain. His channel is a great resource for any kind of lock you are considering, even things like elec front door ones. That hardware linked above will definitely take longer to overcome than loosening a brake line fitting on a brake-locked SxS, without concern of failing hydraulic seals.
Plowboy1466
Plowboy1466
298
1,492
Ashland, Ohio
So as far as l know, the Hilly Break was made for, as l understand, made to not rip your parking pawl out when parked on a hill. lt works great for that. As far as being able to put a lock on it is just a bonus. But l have no idea what the long term effects are for leaving it locked.
Reactions: ChadD and Smitty335
Junkyard
29
52
San diego
I had wondered about this a couple weeks ago. Of course now I can’t remember what I did and will have to wait a couple more to see. It’ll probably be fine either way.
Nevada Notch
Nevada Notch
50
163
Carson City
I would NOT recommended it for long term use.
Puts a strain on the seals of the entire brake system causing eventual brake fluid leakage.......
Junkyard
29
52
San diego
maybe or could keep them pushed out and sealing instead if shrinking and drying out. Stuff is pretty tight in there. Obviously it’s not a good idea long term because it’s not normal. I hope I didn’t leave it locked though. But I really don’t want it stolen either.
ODAMO
ODAMO
1,177
3,206
Ohio
All someone would have to do is cut the rubber brake lines and away it goes......
ODAMO
ODAMO
1,177
3,206
Ohio
They probably have a steal braid in them but ya, if someone knows what they are doing and are determined no deterrent will deter them. But that doesn’t mean you leave the keys in it.
No steel braids in them. Pretty sure all one would have to do is reach in under the hood and rip the ignition wires out and connect them to hotwire it...........And Its Gone.....
Guns and Insurance are your bet bet
Junkyard
29
52
San diego
I’m not going to jail for murder over a sxs. I even have a gun and that never stopped any of the other thefts I’ve had. I do have insurance though.
Junkyard
29
52
San diego
Well it would seem I did get paranoid and leave my hill billy brake locked for a month. Everything seems fine though. my decades of working on cars would tell me to think it wouldn’t hurt anything as it’s ment to be pushed and pressurized. At the same time I wouldn’t want to leave it like that either as it isn’t ment to sit like that. Things like brakes go bad from sitting either way I guess.
mom another note, neighbors leech lines soak to my side of the fence coupled with the rain caused my airstream to sink on one side down to the frame. Luckily I have a backhoe and a mrs junkyard to help.
K
KenThompson
265
603
Mulino
I have the hillbilly brake more for parking. I have the Hess removable steering wheels on both of my cars. I take them in at night. .
Reactions: Hometeam and ChadD
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,657
Oshkosh, Wi
Looking at getting a Hillbilly Brake more for a theft deterrent than anything. My concern is keeping the brakes pressurized for periods of time. How long can I keep the brakes locked before I need to worry about doing any damage? An hour, a day? Thanks
I wouldn't be too worried about the brake pressure. My hillbilly brake hardly works again. Seems the parts are pretty susceptible to corrosion and just lock up over time.
Reactions: ChadD and toddvdh
