P700 Honda 08Z02-HL3-A00 Accessory Sub Harness
BillC
6
7
Pa
Is this the correct harness for a 2020 Pioneer 700 Deluxe I've down a search some sites show that this will work some reviews say it it won't.Want to put some lights on and use a relay and have them thru the switch
Thanks
Reactions: Spook1
QuadMan747
QuadMan747
344
566
Connecticut
www.cccmx.com
  2. Other Brand
Thanks
I'll see what I ordered. It was like 15 to 20 bucks
64,288
I find that this one part #08Z02-HL3-A00 is for the installation of Honda Accessory Horn Kit and/or Back Up Alarm.
S l640
K
KillYourTV
7
0
Syracuse NY
So basically looks like plug and play whips for Ignition controlled power?
64,288
Power yes. Ground is only when in reverse.
We also sell cleaner options kn the store.
BHarris8753
BHarris8753
78
86
Robbins, NC
This is what I used, 2018 700-2, plugged into the red capped connector, has 12v at all 4 wires with key on. Much cheaper to buy at the dealer than amazon.
6A11C4EF BEB1 4143 95CD 2A8ABC17C648
Reactions: Diverguy
K
KillYourTV
7
0
Syracuse NY
Isnt the red one the diagnostic port? Not 100% sure I'd want to be messing with that…
BHarris8753
BHarris8753
78
86
Robbins, NC
I went to my local dealer and compared the different harnesses, the one i posted is the only one i could find a plug and play with. The one that the 700 calls for i think is intended to be used with the oem switch panel and would not work for me. I just used it for key on power, it is not intended to carry a heavy load so i wouldn't think you'd have a problem
BHarris8753
BHarris8753
78
86
Robbins, NC
I dont know about the amps, id say low just as a rule of thump. I used it to power the back lights on a switch panel which are led and my volt gauge and usb ports, the ports are 1-2 amps to charge you phone.
BHarris8753
BHarris8753
78
86
Robbins, NC
If you could figure out which fuse powers that red capped wire that would tell you the amps by the fuse size
dalis7393
44
37
I tested the connector with key on i only have 1 wire that has power out of the 4. Is there another switch that needs to be on to have the other three powered up?
