P500 Honda P1000 takeoffs
W
wtmcminn
23
159
Texas
will these tires fit a 2022 520? they were taken off a P1000 new, and have 4 miles on them, with the stock P1000 wheels too.
Front 27x9R14
Back 27x11R14
4/137 bolt pattern
Neohio
Neohio
Beast of the East
13,392
65,461
Painesville Ohio
Front 27x9R14
Back 27x11R14
4/137 bolt pattern
I am not sure if the overall height will work.
@RB3offroad manufactures adapter spacers. They may have a 4/110 (500/520/700) bolt pattern to 4/137 bolt pattern spacer.
Red500
Red500
5,269
57,114
Greeneville, Tn.
Tires should work but you'll need new rims. But if you stick with 12s you'll have more side wall wich seems to help the ride some.
P
pappyo
593
2,379
4 on 137 to 2022-P520 HAS Been Done.
MASDA RX-7GS Coupe1985 <> 1-inch Wheel Spacers Adapters 4 on 110 to 4 on 137 with 12mm x 1.5 threads studs and lug nuts
Set of 4 <> Purchased E-Bay <> ( $60.99 plus tax ) <> From <> seller <> auto_engineparts
Picture is of can-am commander 4 on 137 bolt pattern beadlock wheels with 27x9x12 ft./ 27x11x12rear tires <> on 2022 P520
All 8 lugs are exposed<>
Front 27x9R14
Back 27x11R14
4/137 bolt pattern
Check tork setting any time
Winter <> change to tracks <> just pull the 4 on110 lugs ( spacers stay on the wheel )
FYI: CHECK the wheel offset of the Honda P1000 to see if simular <>( compaired to the can am commander )
Keep us posted how you make out.
20220531 085207
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
yes we do make the adapter for these. I know that some have used the tires off the 1000 for their 520 and liked them. They usually went with 12 Rim.
