Honda pioneer 1000-6 oil dipsticks
Joshk1908
Joshk1908
Ohio
  1. 1000 6 Crew
Hello everyone! I was getting ready to do the first oil change on a new pioneer 1000-6 and had some questions about the oil dipsticks. Hopefully someone can help. In the area of the oil dipstick there is another dipstick that’s not labeled and I’m not sure what it is. Can anyone help!?
988EB9CC 96EB 4D66 8F48 32A2357C7D57
Reactions: Scoop and Smitty335
Joshk1908
Joshk1908
Ohio
  1. 1000 6 Crew
I did find the sub transmission one as well. Has anyone been changing the sub transmission oil with the first oil change even though it doesn’t say you need to?
Joshk1908
Joshk1908
Ohio
  1. 1000 6 Crew
The arrow should be the dipstick.
The other one that says oil is where you should fill it. Your not supposed to fill oil at the dipstick.
Also, find the sub transmission. There is a dipstick there too.
Thanks smitty
TripleB
TripleB
12,145
103,728
Caryville, Tennessee
Don't waste your time or money. I changed mine at 2 years and I don't remember how many thousand miles. It still looked good. I've also seen a talon with hundreds of miles with no oil in the subtrans with no damage. I've got over 13k miles on mine now and I don't know if I will ever change it again lol
ODAMO
ODAMO
1,207
3,288
Ohio
Change all oils, even the diffs. One, you'll know they are proprly filled. Two, you get to know your machine a little more intimately. Three. You will sleep better because of it.
bigred1000-6
bigred1000-6
Buckeye,AZ
  1. 1000 6 Crew
I also have the 1000-6 and 90miles on it. That is the dipstick on the bottom and fill on the top. I was asking the forum as well but on the front and rear gear oil. People replace it at 100miles but the book clearly says Check level and on the second section of the maintenance chart it specifies Replace every two years along with sub transmission oil, brake fluid, coolant. That’s what the book calls for.
IMG 5077 IMG 5076
Scoop
Scoop
4,495
17,433
  3. Talon R LV
Only a dipstick would fill oil at the dipstick.
Wait: My wife asked, "Isn't that where the oh-lee goes?" 🤣
