Resource icon
P1000 Honda Pioneer 1000 Oil Change Guide!
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
Noob question: Is there any stipulation regarding the warranty when service is done? Either factory tech and/or Honda parts? Not so Noob question: Is there some kind of silcock adapter like the easylube guys install to facilitate an easier draining. Last thing. Thanks again for details like these, it's this kind of thing that makes this site such an amazing resource. I cant wait to revisit these instructions when the time comes.
Keep your receipts for proof that you did the service though and write down the hours and miles so you have a log of said service
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
Have any of you guys tried one of those vacuum oil sucker things? I'm wondering if it would make less of a mess if you got more out first. I've had luck with other vehicles using a piece of folded paper or the box from an oil filter to redirect the oil. Works especially good on GM vehicles that have the factory skid plate to use the oil filter box
So the vacuum sucker thing didn't do a whole lot. Between the engine and transfercase I think I got 3 liters. The drain plug in the middle barely made a mess though in my trail armor skids. The rear plug was messy and the transfer case one too but that one had I planned a head you can easily put rags or paper to guide it out to not make a mess. I think you could do that with the rear plug on the motor to help too.
Either shoving rags below the filters or using cardboard and some tape would greatly help with the oil filters. There's a pretty good charge of fluid that drops out of them as well.
Thanks for the write up. There was definitely parts that helped me save some time.
Reactions: Hondasxs
jpgoody98
jpgoody98
Kearney, MO
Great write up thanks!
I bought your suggested funnel too, well worth it, works great, I zip-tied it to the ROPS just below chest height, worked great!!
I will be taking my skid plate(factory) OFF next time forrrrrr sure!!
Be careful with the the filter covers, I assume that's aluminum. 9-ftlbs is light, i put my hand around the very base of the rachet to serverly limit my force applied, then snug it up tight.
bdiesel3
16
West MI
Picture 9 of 23 says to change the DCT filter first, I noticed you changed the engine filter first, does it make a difference or not? Thanks
266,509
I changed my DCT oil filter first since it was on bottom, but you only have to change the DCT filter every other oil change while you change the engine oil filter every oil change. For $7 I'm changing them both filters every time. But it doesn't matter really, go against the grain be a rebel. :cool:
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
I agree, change them both. They're in the same oil so it doesn't completely make sense to me why they wouldn't want you too in the first place.
Reactions: joeymt33
ghost
ghost
993
1,873
BC
What's with this procedure to check the oil level?
I was not getting consistent readings so I used a stop watch. Ran it for exactly 5 minutes then turned the engine off and tested at the following times:
1 minute - hit the lower mark on the dip stick
2 minutes - about 2/3 between upper and lower marks
3 minutes - at the top mark
4 minutes - over the top.
WTF... are we supposed to carry a stop watch. Then if its low you have to add a couple ounces and run it again for 5 minutes.
dale5740
dale5740
886
417
mt airy md
dale5740
dale5740
886
417
mt airy md
I made a mistake and when I put the filter cover back on the large filter cover I rotated it to the right so eng stamped in the cover is now vertical will this cause any problems??? thanks for your help
63,988
I don't think so. Look at step 4. You can see there is really no reason for it to be one way or the other... Other then the bolt holes lining up.
dale5740
dale5740
886
417
mt airy md
thanks after looking at the pic u pointed out I don't think it matters if someone does think it matters please post why thanks again!
dale5740
dale5740
886
417
mt airy md
does anyone know weather the pioneers come with break in oil in them to start? reason I ask is because I have seen break in oils in the past that were dark to start with?
63,988
I am fairly sure they don't use anything special. Just normal GN4!
dale5740
dale5740
886
417
mt airy md
I was just curious cause I changed my oil and it looks dark in a clear glass but looks great on a paper towel
dale5740
dale5740
886
417
mt airy md
IMG 1347
IMG 1346
IMG 1345
Reactions: Haldog77
Hawk53
Hawk53
464
591
Alberta Canada
Thanks for the info. Haven't had to do this yet because I won't get my machine until next week.:) Love having the info before hand.
ghost
ghost
993
1,873
BC
oil on left is out of my machine just over 100 miles looks clean in towel looks dirty in glass on the right is new honda synthetic
Thats how mine looked too. I think its just a result of the break-in - not special oil they put in.
