You tore it apart how many times?Lost reverse so took sub out put reverse gear ,reverse idler out of talon plus replaced all the other gears that was bad put it back together it just grinds in low so tore it apart a hundred times went through the book step by step
I followed your steps everything lines up with the cover onP1000 - Sub-Transmission Service
I replaced my reverse and low gears in the sub-transmission this week. It was my first time going through the sub-trans, but I learned a lot that is useful to pass on to anyone getting into this. The first part of this is a guide to removing the sub-trans. You may need to get into it for...hondasxs.com
Pay really close attention to where I called out issues and things that weren't clear or consistent in the service manual.
I reinstalled in neutralYou tore it apart how many times?
Did you follow my sub-transmission service thread? There are a few things I pointed out in there that the manual was not very clear on.
Just a first thought, I wonder if you got messed up on the reinstall in park / neutral problem?
I went ahead and ordered the sub-gearshift fork and the low final drive gear because I heard they can be messed up from the reverse getting to the condition this one was in.
