Talon Honda Talon X4/X4D Installation Instructions
Plan on posting Honda Accessory Instructions here like the other thread for the R/X. Will only be posting 4 seater specific instructions. Any current 2 seater accessories that also fit the 4 seater are available in the other thread.
@Hondasxs Feel free to sticky thread.
  • 4 Seat Aluminum Roof.pdf
  • 4 Seat Fabric Rear Panel.pdf
  • 4 Seat Fabric Upper Doors.pdf
  • 4 Seat Floor Mats.pdf
  • 4 Seat Frame Skids.pdf
  • 4 Seat Nerf Bars.pdf
  • 4 Seat Rear Panel.pdf
  • 4 Seat Side Skids.pdf
  • Rear Aluminum Doors.pdf
  • Rear Lower Door Panels.pdf
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Maybe correct spelling on the other thread title?
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I never said I was good at spelling.
I don't believe I can change the title after the fact.
I was just teasing hondasxs.
i bet he can edit it. (When making stickies.)
As promised, 4 seater specific instructions are now live, shoot me a message if something is incorrectly labeled or doesn't work.
Just a heads up for anyone with a 4 seater who plans on installing the Honda switch plate/volt meter. We just found out today (our first install of this accessory on a 4 seat) that Honda doesn't have a different part # for the 4 seater. This poses a problem since the switch plate receives power from the battery and the switch plate only comes with the enough harness length to reach the battery on a 2 seat.
Apparently Honda has made a Power Harness for this particular situation and has forgone any mention or inclusion of the need for it in the switch plate instructions, nor have they ever mentioned it except for in a accessory availability message wee received this morning.
For those installing this accessory you'll also need 0SA31-HL7-A00 to install it on a 4 seater as well as the sub harness 0SZ08-HL6-A00. If you plan on installing or have already installed the Honda winch then you will not need the sub harness (0SZ08-HL6-A00).
