![Ridinfool](/data/avatars/m/23/23705.jpg?1585676729)
Ridinfool
Thinking about putting a radio in my buggy, how big of a radio can I put without a lift?
Will that work if I’m only running rec 88 1/2 gas?Forward arched rops clamps is the way to go. Then you can fit the Pioneer Super Tuner, it's pretty big.
Nomo whatsoever
I’m running the Betti cooler, according to the guy I bought it from, it’s the same thing as a Yetti…Depends on what brand cooler you carry with you.
I generally load everything I need in the buggy before I ride… is that what you mean when you say “preload”?Sometimes it depends on the preload 🤣 🤣 🤣 🤣 🤣
Yes , yes it is 🤣 🤣 🤣 🤣I generally load everything I need in the buggy before I ride… is that what you mean when you say “preload”?
I tried that and only things that came up was a bunch of red writing…Use the search function in the upper right hand corner, lots of threads on this subject.
🤔.....all depends on how many stations you want to listen to 😉Thinking about putting a radio in my buggy, how big of a radio can I put without a lift?
As long as you throw a cross tie in front of the tires it should work fineWill this trailer be ok?
That looks more like a trailer for a P5 not so much a P1KWill this trailer be ok?
Ok good, I think my F-150 should pull it fine.As long as you throw a cross tie in front of the tires it should work fine
ACV/AMP Babes think preload means foreplay 😎I generally load everything I need in the buggy before I ride… is that what you mean when you say “preload”?
Especially if it's got the 5'6" bed......😂😂😂Ok good, I think my F-150 should pull it fine.
I always thought foreplay was 30 minutes of beggin…ACV/AMP Babes think preload means foreplay 😎
Even the ugly ones!!!
