P500 How to: P500 Starter Replacement
ehart814
ehart814
1,654
3,643
NWPA
Well after some intermittent starter issues, she finally bit the dust.
This is a hard one boys, so stay with me!
Step one- get new starter
Remove old starter. It is accessed through the drivers side of the machine. It might be a bit easier if you remove the drivers side rear wheel, but it’s not needed.
NOTE: you will need to reuse the nut that holds the starter wire to the starter terminal. Do not remove the new nut that comes on the new starter - the wire goes over it.
Two bolts hold the starter in. You need a 12mm socket or wrench. Remove the bolts. One of them is also holding a ground wire. Then use a 10mm socket to remove the nut holding the hot wire to the terminal on the starter.
Move the wires out of the way and start yanking on the starter. It won’t be eager to come out. You can stick a screwdriver under the ear (where the bolt goes through) and pry while wiggling it. Eventually the old starter will come out.
Pic of where the starter was:
C4ce95f2238bcf8fae29a76d2daacaff
Now take your new starter and put some grease on the Oring.
990d9417080acbb5f7ce8f25b2a85a92
Stuff it in the hole!
Aa2914744f79acd747ceb2d8a4d18ce5
Replace the bolts, making sure to run the passenger side bolt through the ground wire...
Attach the starter wire to the terminal.
Efd1e41ae743a2401bda637d91d5d89a
Start the machine and ride. It probably took me longer to type this post than to make the repair. Didn’t even take long enough to finish a beer. :(
Also, this job could be done on the trail if needed!
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
My starter sounds like a dentist drill is that what yours was doing?
Not trying to say you did it wrong, as that seems to be the simplest way.
But for me, I remove the 8 bolts holding the rear rack on, remove 1 mud clip holding the air snorkel tot rear fender, unplug the taillight harness and remove the rack and fender in 1 piece.
Now you have all the room in the world to get that bad boy out.
158,515
Yeah, taking the rear rack and fenders off is easy in its stock form but depending on what's been added to the rear? It's a full days job taking mine off and probably 2 days putting it back together. I'd opt for the wheel well access in my situation.
Judge
12
Followed your instructions and put in my new starter today. One tip.After you get the hot wire off (10mm) and the two bolts (10mm) i could not get the old starter out. No place to pry or grasp.I tied a piece around one of the "ears"that the bolts go through and pulled the rope out the back of the sxs. one tug and it popped right out
BigRedMac
5
Vermilion, OH
Same thing happened to me....started just stopped about 2-3 weeks ago. But now after replacing it, it starts & runs, but the paddle shifters don't work? Any ideas?
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,769
183,148
Grand Junction, CO
This may help also.
  • P5 Starter Removal Install.pdf
Y
Yukon_Jon
12
27
Yukon Territory
I recognize this is a two year old thread, but it just became all of a sudden very relevant to me, unfortunately. So thanks! Made things very straightforward. I was going to pull the whole rear off, as suggested elsewhere. But this is definitely faster. If a little more cramped :)
Reactions: Mudder and trigger
CTRCME9
Nc
Thank you for the step by step on replacement of a bad starter. I must ask about how long did it take to remove old starter and install the new one. I decided to take my machine to a Honda sales/repair shop and I don't want to be charged for idle hours at $90 an hour. According to the manufacturing plant technicians it should take now longer than 2-hours for a novice to change it. Since I am new to this forum any and all information is a plus. Thanks again for your input.
Reactions: Bigtee
CTRCME9
Nc
I joined the forum yesterday, 11June, I have had no idea what was available out here on the web, especially a forum like this. I live in NC, and purchased my P500 after joining a hunting club since the club parking area and hunting areas are about 1/2 mile from each other and I hunt the far back side. My grandchildren call the machine the big Red bike and love riding in it. My wife takes it out as often as she can. I think she has more hours in it than me. The P500 is/was a great choice for us. Glad to be a member here.🙂🙂
PJ1
PJ1
FIREBALL P-500
1,289
13,906
Massachusetts
After a recent washdown of a muddy p500 my starter is whining like a little b****. Was fine until I took the hose to it.
Wow can't say b****? b****.
  • Haha
Reactions: CID
L
Labeef
6
12
Hope, MI
Just did this starter swap. I removed the left back wheel and used my loader to lift the sxs up a few feet. This allowed my 74 year old body to sit on a crate and do the job. Only trouble I had was getting the new starter to seat all the way in the hole, the o ring offered some resistance so I installed the mounting screws and carefully tightened them a turn at a time to draw the starter in and seat it. Overheating was the cause of failure, the glue holding the magnets came loose and locked up the starter.
Reactions: PJ1 and trigger
207,989
What caused the over heating?
PJ1
PJ1
FIREBALL P-500
1,289
13,906
Massachusetts
I think water is the issue dissolving the glue holding the magnets.
L
Labeef
6
12
Hope, MI
No water involved, grand son was ridding around our property in low gears on a hot day (first time driving alone) and when he shut it off after 15 minutes of driving, I went to start it and the radiator fan came on and when I keyed the starter, only the click of the relay. Checked the coolent temp and it was high. Took the starter apart and many of the magnets were detached and were locking up the starter.
I use this machine everyday, year round on our farm so 5 years of use was a good run for the original starter
