Installing a 4 PT harness ?
MFG
MFG
191
293
East Texas
How is the best way to work with the driver side seat belt system that limits the engine RPMs when not attached.
Very simple. Buy the bypass plug from this forum. Plug it in and you are done. Takes about 3 minutes
Neohio
Neohio
Beast of the East
13,477
66,519
Painesville Ohio
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,657
Oshkosh, Wi
Get the plug and Can-am harnesses and you can keep the speed limiter and have 4 points
Reactions: BWAF
nm6r
nm6r
78
173
Sandia Park, NM
I just cut the oem seatbelt wiring up a couple inches from the connector, soldered and heatshrinked the two wires together. It's easy enough to put back to stock if I every wanted to. It's an immediate, zero dollar solution that allows the use of any harness.
Reactions: BWAF
