P700 Intermittent starting issue.
2tracks
2tracks
Hello all, I'm new on the Forum here and already need help. Bought my first pioneer a brand new 2020 700-4 M this April. I have 600 miles and about 30 hours on it. It's left me stranded in the woods three times. Each time I shut it off in the woods and it would not start sounded just like a dead battery. Battery has been removed and tested and checks out okay. The dealer has replaced the starter and solenoid but could not find anything else wrong with the unit. Start issue is random and we have not been able to duplicate the starting problem on demand so it's difficult to diagnose. Anyone else having this problem?
Reactions: TripleB
64,288
Hi,
What year is it?
Its common for ground points to be loose and will give issues like mentioned.
There is a ground on the frame and one on the engine.
I'll try to find a image tonight.
Reactions: wrhii and TripleB
2tracks
2tracks
Hi,
What year is it?
Sorry, it's a 2020 and still covered under warranty. I Wish I had a wiring diagram for it. Of course it starts every time for the dealership. The only reason they believe me is because I've taken videos of it not starting when it has occurred.
Reactions: wrhii
Dayooper77
0
49783
I have a 2020 700-4 and battery is dead! I have had on slow charge for several days. I hope I don’t have to buy two batteries per year going forward. First cold weather killed it.
  • Sad
Reactions: DG Rider
42,130
Nah. You occasionally get a bad one, but they should last a couple of years at least...unless you are constantly running it dead.
O
oldfortyfive
596
1,321
Illinois
Back in the 80's Interstate did bad run of car batteries. I went through 3 in one month.
NTCPrezJB
NTCPrezJB
President of #NTC
101,966
910,891
Canton, OH
Have you or your dealer checked the Stator? I don't know what the specs are but maybe it's not quite up to par and slowly not getting enough charge in the battery.
Also, pickup a jump pack in the interim so you can at least always get back if it is giving you trouble. They are small, pretty inexpensive and versatile tools at this point.
Reactions: BigMac
Dayooper77
0
49783
I checked it last night. About 8 volts. Shot I think. I’m sure it’s not a warrantee item? Bought sxs in May this year.
