P1000 Intermittent stuck in 1st
blackbirdls1
10
23
FL
Have a 2020 pioneer less than 1k miles. It sometimes will go into what seems a limp mode. This happened out of nowhere. The gears will shift from park to reverse etc, but it will sometimes will only stay in 1st. Any ideas?
JenElio
JenElio
65,087
609,198
Loxahatchee, florida
Just joined, welcome from South Florida 🤘
Make a intro thread when you get a chance and post some pics of your buggy.
.......just to rule it out, could it be the seat belt safety switch deal? That'll only allow you to be in 1st gear I believe
Reactions: Remington
107,327
Welcome from Michigan!
Like stated above, pics of machine required or….PICS OR IT DIDNT HAPPEN!
With the 1k miles, how much is ripping on trail, Ideling or putsing around?
If most of it is the ladder, change your spark plugs. They will foul quickly that way and when u go to put it in gear, voltage and such matters fo sho… but if u have a fouled plug it will do what your describing as well. Your also on yr 4 of your stock battery. Do a Load test with a LOAD TESTER not a meeter on that battery. Simple things first, work smarter not harder.
Reactions: JenElio and EMAW
blackbirdls1
10
23
FL
I’ll take some. It doesn’t see mud or trails. It’s just a machine that works around the property.
P
packer58
304
917
N. Cali
Maybe check your grounds also, seems to be somewhat of an issue with the electrical system ....
Reactions: JenElio
tjoreo
tjoreo
1,011
1,929
Southern Idaho
If the gear indicator is stuck in 1st and it is flashing the 1. Count the series of long and short pulses and that will tell us what code your machine is throwing.
blackbirdls1
10
23
FL
Yeah I checked some wires. Seem solid. How many grounds exist?
yeah it did that but after running it a bit. I’ll try to replicate
blackbirdls1
10
23
FL
Pic of her
IMG 1314
107,327
Reactions: JenElio
P
packer58
304
917
N. Cali
I believe there are three (3) main grounds to the engine, I also believe there's a location diagram floating around .............maybe try the search bar for that one ......
tjoreo
tjoreo
1,011
1,929
Southern Idaho
If the number "1" was flashing it is telling you a code and where maybe to start looking. If it does it again count the long and short flashes or even take a video of it. We can then check the service manual to see where to start.
Jankyeye
Jankyeye
564
2,527
Tampa, Fl.
Other than the tires that thing looks brand new! Welcome from Tampa, Hopefully you get it straightened out.
Reactions: JenElio
blackbirdls1
10
23
FL
It just did it. Seems like long flashes and 2 short flashes at the end.
107,327
How many long flashes?
The amount of long flashes followed by the amount of short flashes = the code
