Introducing Honda Talon Quick Switch connectors for Acc Switch Harness!
66,854
If you purchased the Honda Talon Switch Panel you quickly noticed the 5 white connectors wondering what can I do with those??
We are pleased to announce a simple and easy solution.
The Honda Talon Quick Switch Connectors from HondaSxS.com
20190512 215601 1024x1024 20190512 220146 1024x1024
20190507 102714 1024x1024 20190511 151005 1024x1024
This makes installing your custom accessory and switches easy. They are completely plug and play. Once you ordered your standard SPST switch then just plug it in and wire your accessory up to the provide pigtail and you're done. For switches, we recommend SPST On/Off from OTRATTW.com
We offer the following.
  • Single Quick Switch Connector (On/Off)
  • 5 Pack Quick Switch Connector
  • Winch Quick Switch Connector (MM)
  • Combo - 4 Quick Switch Connectors and 1 Winch Quick Switch Connector
BUY HERE --> Honda Talon 1000 R/X Quick Switch Connector for OEM Switch Panel Kit.
We also find just the pigtails here to build your own custom item - Honda Talon Switch Panel Accessory Pigtail. DIY
We can also build any custom configuration you like as well, just shoot us a message to open up a conversation.
Installing is easy.
2f847d0e84c52c8640c676258e876141 772420065a7ac99d55315d3510149470Tapatalk 1557239097934 1024x1024 47e6e17b6e59aae6ad609460e5258438 C322cfe5d303c32d03795785d3446f3a 586e02139d40d42f22631e83c96119b3
