ITP Tsunami 15 inch Rims - Will they fit Pioneer 1000
MTLuckyDan
38
51
US
Looking to run 235/75R/15 tires on ITP Tsunami Rims in 15x7 w/4/137 pattern & 5/2 offset. Looking for anyone running this rim or similar ITP rim to confirm fit & anything I need to consider. I have one inch spacers for rear tires & ordered some Yokohama Geolander MT tires to try. Thanks for any information.
Sent from my P00I using Tapatalk
Reactions: BWAF
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
The tsunami wheel is damn good lookin.
I see no reason it wouldn’t fit, 5+2 is the correct offset..
But why 15’s instead of 14’s?
Reactions: BWAF
russknight
russknight
1,910
7,506
Perry Florida
And these wheels.
https://amazon.com/gp/product/B017OF96G2/?tag=sxsweb24-20
Not bad for 45 bucks each and they machine balanced perfectly.
Reactions: 100Acre and BWAF
MTLuckyDan
38
51
US
Is the 6 1 offset on the front apply with the 1 inch spacers on the rear as well?
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
@my99svt will know
BWAF
BWAF
8,857
42,437
Carthage MO
My bad thought it talon question
BWAF
BWAF
8,857
42,437
Carthage MO
Here's the wheels I put on my Pioneer with one Inch spacers in the rear only 6f9cc439baf4d39d8c0c6c55e40a2df0E4b539b25f85ef2ed329bcb827debd6438bee7e0179d1f6250bb4034aa75ac9f
Reactions: Remington
Sjc3081
Sjc3081
263
442
Wappinger NY
6+1 front and 5+2 rear will provide near perfect factory width. If your going to use a large 28/10/14 front tire it may not fit. 27/9 or 28/9 should be fine on front. I have 28/10/14 Rip Saws on 5+2 Split Six wheels my front width is now 66” and my rear is 62”.
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
No. A 5+2 wheel on all 4 and 1inch spacers on rear is perfect alignment.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
No 5+2 off set in the front will increase your front width to 66”
It seems like you're going about things the hard way. The factory wheels have a real funny offset and are not the same front to back. It makes no sense but they are basically 1in different.
If the end goal is to have your tires inline front to back then getting 4 wheels that are the same offset such as 5+2 and adding 1 inch wheel spacers to the rear is the easiest option. You will also benefit from being able to use the same wheel on all 4 corners. Futher, you'll have more clearance for turning the front tires if you use the 5+2 wheels.
Reactions: ChadD
someguy1313
someguy1313
172
377
SouthEast
from the dead:
@MTLuckyDan and @Sjc3081 and others?
still happy with Sedona bead lockers? and the HD alloys?
107,315
from the dead: still happy with Sedona bead lockers? and the HD alloys?
If your asking the OP (no tag) he hasnt been on in a year. Might want to send him a PM, he might get an email and respond.
@BWAF is still around, still has his rims but he uses LT tires and yes they are still good.
