P500 ITP Ultracross
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Just got back from our first ride with the new ITP Ultracross tires. Wow, what an improvement over the stockers. We chose the 27x10x12 all around. Improved ground clearance, traction and riding comfort. Eight ply radials running 10lbs in the front and 11 lbs rear. Will play with the pressure next ride. Stock rims with 2" spacers on all corners.
67116062092  953038E0 8D72 4602 8FD1 D9782D93C9EC
67116065932  B7E35677 D226 449B A3F5 389459133702
67116068512  4FCB251C 4026 4E99 B182 9A237D5F33C6
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Kkettlebell
Kkettlebell
114
475
Nova Scotia
toddvdh
toddvdh
1,070
7,021
Green Bay, WI
I have the same tires on my talon. Different size, but I have played with pressure quite a bit. The pressures really change these tires.
At 6 psi they are super conforming in the rocks, and a super squishy comfy ride. Excellent traction.
At 11 psi the still hook up and are still a little soft to ride hard. They still have good traction and a nice ride.
At 15 psi they turn way harder. You can spin them easy, and slide around corners.
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Thanks for the info. Yea I was thinking around 8 lbs for the rocks. Even at 10 and 11 lbs they were great. Loose rocky grades on the trail you couldn't even tell it was an open diff in front.
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Have you had these on trails? How did they do?
The last ride was a mixture of gravel road (Pics) Sand wash, Loose rocks and literal boulders. Great in Sand. We followed a stream bed for about 1.5 miles with boulders intermixed into the recipe. Next ride I'll lower the pressure a couple pounds.
IMG 5397
IMG 5401
Splorin
299
838
Maine
I've run ITP 10s on OEM 6 and 7.5" rims on another machine in the past. Took some trial and error to get the psi where we liked it. It was way more of a slider than a P-5. Front beads well protected. 9&11 eventually was the all around psi..........
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Thanks, Close to that now.
Reactions: 1border4manu
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Same tires but on new wheels. Moose Racing. 7" on the front & 8" on the rear. 4x3 & 4x4 offset. Took the 2" spacers off and gave them to a good friend with a 2020 P5.
IMG 6659
IMG 6660
IMG 6662
Rdrcr
461
2,530
WA
How bad will the 27x10-12 rub on stock wheels without spacers?
Mike
Reactions: Backwoods
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Mike
I don't think you would have problems with rubbing. These tires are at 26" overall on 7" & 8" wheels with 12 PSI. They run short of stated size. I did run the spacers all the time but had plenty of room lock to lock.
Reactions: Rdrcr
