P700 Jerking
G
GrandpaJ
6
Holton Indiana
I have a 2016 700-4 with 108 hours on it problem is when it gets warmed up good the transmission will not engage after a stop and go until the motor rpm goes up this causes a jerk to the machine any ideas?
swsebek
swsebek
2,854
5,829
pa
Check oil level
Should only do that if it's cold start up
What oil you using
jawquin
jawquin
299
652
Indiana
Hi GrandpaJ, Welcome to the forum. I have a 14 that is broke in and I think I can relate to what you may be mentioning. Mine will do it at times after it's hot. Rpms come up a bit before moving and a slight jump. I have always run Honda GN4 and always overfill it a bit on oil since new. I don't worry about it though it might catch you off guard when trying to just move.
G
GrandpaJ
6
Holton Indiana
I took to dealer they could not find any issue changed oil said all good
Does motor and transmission share same oil?
266,620
Yes, both are run off same oil supply.
266,620
I am not sure what oil the dealer used is there a recommended oil anyone uses? It seems to me maybe oil to thin
You can't go wrong with the Honda GN4 10-w40 oil recommended by Honda.
Reactions: swsebek
G
GrandpaJ
6
Holton Indiana
Ok thanks
You guys been around these longer than me any advice is surely appreciated
I just don't think that the jerking can be good on drivetrain
G
GrandpaJ
6
Holton Indiana
Does the 700 have clutch solenoids?
How exactly does the clutches engage?
266,620
It has a torque converter and and automatic clutch 3 speed transmission, much like a car of yesteryear. Like stated earlier, this powertrain is based off Honda Rincon ATV first appearing about 2006 at 650cc then bumped to current 680cc around 2008. I had two of them, no problems but they certainly had thier quirks in cold weather or when engine wasnt warmed up (actually oil temp) as they would be sluggish or hesitant to move until warmed up fully.
