P1000 Keep Factory winch or upgrade?
screaminfast
screaminfast
17
44
Rochester NY
Just pulled the front bumper off today (snapped a bolt :mad: ) and pulled the winch. I was gonna change it to synthetic and a hawse fairlead. Should I just upgrade the whole winch instead?
Also since I have the factory warn plow setup do I need to change the roller on there to something different?
Couple pics attached
64725B67 A4CD 409B AB86 0927FBC9AD93
D35ECCC7 6EDE 4E22 A8EA CF4767DA49A0
ADE4BAEE 68EC 4553 ADBA 4BB7723B86A4
Reactions: ChadD and Lady01
Rayger143
Rayger143
2,755
23,870
Winfield, BC Canada
I have the same winch and it works great. I also changed to synthetic rope. It is much nicer to use. If it works, why upgrade? If I do any hard pulling I use a snatch block and have never had a problem with the factory warn winch.
screaminfast
screaminfast
17
44
Rochester NY
Any issues using my factory plow you think?
Reactions: Lady01 and ChadD
Scoop
Scoop
4,250
15,923
  3. Talon R LV
If you're not having any issues with it, no real sense in upgrading, other than replacing that steel cable with a synthetic rope and fairlead with hawse. Might be worth disassembling, cleaning and regreasing.
Scoop
Scoop
4,250
15,923
  3. Talon R LV
Right but what about the little pulley on the plow frame? Change that out too?
Not sure which plow setup you have. Are you referring to the pulley in the rope guide? (This is not mine - found this pic on the Interwebz):
1639667144529
My ATV plow setup uses a Warn 92100 push tube. The rope guide/pulley is on the push tube like in the picture above, except wheel in the pulley that's connected to the push tube is nylon/plastic, not steel. This is what mine looks like:
1639667388830
1639667015138
O
oldfortyfive
596
1,321
Illinois
That's just a guide. You'll be fine with it. The winch rope really doesn't move it in.
Reactions: Lady01
Scoop
Scoop
4,250
15,923
  3. Talon R LV
It most certainly moves, just not a lot. If it "really didn't move", it would not be a round wheel (that rotates) with a pivot point (in most models).
What's NOT good with the steel pulleys is if/when the synthetic rope gets caught between the wheel and the wall of the mount -- then you're on the bolt and risking damage.
screaminfast
screaminfast
17
44
Rochester NY
Thanks for the info so far everyone!
Ended up pulling the steel cable today and mistakenly took apart the gear side thinking I needed to. Is there any cleaning or maintenance I can do while I’m in there?
Also, @Scoop ill snap a pic of my plow tomorrow.
D195E4A1 983C 4EB5 98F4 DE854ED14136
Rayger143
Rayger143
2,755
23,870
Winfield, BC Canada
Clean and re grease.
screaminfast
screaminfast
17
44
Rochester NY
Simple enough. Any special grease to use? Also brake cleaner to clean the old grease?
Side note, I’m looking at the 1/4” synthetic on Amazon and most have an eyelet on the winch side…. Do I just cut that off and fold it back on itself to attach to the drum?
Rayger143
Rayger143
2,755
23,870
Winfield, BC Canada
I can't remember how I attached to my drum on the warn. I have 4 winches and have changed them all to synthetic rope. I'm sure you will figure it out.
bumperm
bumperm
1,851
6,657
Gardnerville, NV
I bought a synthetic rope and an aluminum hawse for about $50. It was simple to replace the wire rope to upgrade to synthetic line on the Warn 4,500 lb winch that came on the SE. No need to remove or pull anything (unless something is broken), I've heard some don't bother to replace the roller fairlead (if it's new and rollers are smooth - otherwise it can trash the synthetic rope).
screaminfast
screaminfast
17
44
Rochester NY
Got the winch cleaned up with brake cleaner and ran it through the ultrasonic cleaner too. Gotta order new warn tie rods and repack it up. Do you think I need to order new seals also?
47776C52 730A 4976 A049 A27DA1207F49
