BOX1 - TEST
KFI Winch mount
bfair
bfair
56
I installed the KFI winch mount on my pioneer It is a very well built and designed mount.
I am very happy with it and it was a very simple install.
Good to know I am still waiting on mine and I was worried it was too light, I have a bad habit of designing something then overbuilding by 500%.
I
idahohntr
141
5
I finally got mine installed this weekend. However I had to grind 1/8" off the bottom of the fairlead bracket due to the cable rubbing. Anyone else have this issue?
Mypioneer
36
11
Arnaudville LA
Great mount! Tried other brand but returned it. Well made product.
Jeepers
I'm going to put a winch on mine but not for sure what brand to go with mount that is I already have the winch off my grizzly I traded in
63,541
Jeepers,
Welcome to the community.
It seems the top mount is the best option. What most like about it... is the fact that it's fully visible. You can see how it is winding and insure it winds up correctly. Having the other style, the internal style, it is more difficult. Plus with the top mount the winch right side up vs upside down.
Here's another pic of the top mount from MyPioneer's P5!
2255
63,541
Jeepers, Kinda got one sided there....
Forgot to ask. You looking for a P500 or a P700.
P5 is above. Get the KFI for top mount as shown.
For the P7 there are several models. All are internal unless you get the front bumper.
Jeepers
I have a 700 p2 the winch is just a 2500 lbs I know it's under powered but the majority of its use will be to assist me to pull up tree stands and light duty. And if I ever need to use it for more heavy use I'll use a snatch block
duwops
duwops
231
45
Keepers
Jeepers no problems with 2500 if your not burying yourself deep or trying to unstick someone else that is buried. I have the 2500 KFI syn and use it for plowing, pulling brush and unloading equipment from my trailer. Being mindful of weights of work required.
AlR
AlR
470
1,166
Nanaimo, British Columbia
Put the KFI mount on my 2017 P500 yesterday. Went on easy. The two u-bolts were alittle tight so spread them about 2 mms and they went on fine. it's a good solid mount. Paint is the same black as the stock Honda black.
20161211 094225 resized
20161211 100341 resized
Reactions: Tflynn
Similar threads
Replies
11
Views
4K
BOX2
box3 - TEST
