P1000 Lift kits
Jakins52
5
Minnesota
30’s.. but you have to have forward offset a arms to run larger than a 28.. lift or not
Ok nice ya was looking at the high lifter or the super ATV 3 in lift with 28in maxxis Carnivores. Would I need to get a wheel spacer at all with a lift
57,047
Any particular reason you want to do the lift if you're going to stick with 28's? Not knocking it, just curious. You'll probably want to add some width but how much would be based off the wheel offset you are running.
Jakins52
5
Minnesota
Well took it in to my shack last weekend for the first time and bottomed out quite a bit so figure if I get the lift and sell my 26 maxxis bighorns 2.0 and getting a 28 carnivore or maxxis 3.0
Reactions: Adam490
Do you have a good after market skid plate?
I love my GC but also have to run the lift with the particular tires I’m running. But if you go up you should go out too.
Reactions: Jakins52
L
Lenzie
11
31
Wesson Ms
I’m running SATV 3” lift along with SATV
Forward and rear A arms . 1 1/2 wheel spacers up front and 2” in the rear
Combined with 30” Zilla’s . Runs great !
As soon as the gear reduction comes in
I will have it installed and move up to 32” tires . I have to hand it to SATV everything fit with no modifications.
990FB1A1 7738 458F B3B0 BA2740B68CBF
87F8EFF1 470C 4CAC B548 DB7DDD22AB2E
1081302F F38A 43AA B80B AA00492ACB6B
brassnozzle
7
6
Florida
So if you have a super atv 3"lift, do you still have to have foward A Arms to run a 30" intimidator?
Reactions: Isaiah
brassnozzle
7
6
Florida
I bought the super atv 3" lift not knowing I needed the arms for a 30" intimidator. I thought it would fit.
Ok thanks. Can you run the 30's with just the foward A arms only? Thanks for the reply.
Depends on the 30’s.. my berserkers I have to have the lift. They run large. Most tires don’t run true to size, so a 30” xyz brand may not be the same as abc brand.
brassnozzle
7
6
Florida
Yeah I just got the 30" intimidator with the super atv 3" lift. I might just return the lift and go with the foward A arms.
JenElio
JenElio
65,078
609,045
Loxahatchee, florida
I will have it installed and move up to 32” tires . I have to hand it to SATV everything fit with no modifications. View attachment 163883View attachment 163882 View attachment 163881
Nice ride! Did you also need axles? Or do the stock work? I'm looking into the exact same set up. Thanks
107,315
I think it’s recommended but I’m not sure? When I had a lift with stock arms I did not. I no longer have the lift and just have STAV arms and still have standard length axels
Reactions: Isaiah and JenElio
brassnozzle
7
6
Florida
Super atv recommends upgrading the axles if your running the super atv foward A arms and lift combined. I returned my 3" lift and just went with the arms from super atv and 30" intimidators. I think you'll need the axles if you run both combined.
