Ditto!I have a 2.5 lift and offset a arms stock axles and It works fine. They didn't bind at all
Hey I meant to ask a while back, have you done any spacers being that you have a lift? I figured if I went up I'd also want to go out just as much if not a bit more. Stability wise I think it could use it.I have a 2.5 lift and offset a arms stock axles and It works fine. They didn't bind at all
Not yet it's in my list though. right now it is 67in wide and it has 17in of ground clearance from the centerHey I meant to ask a while back, have you done any spacers being that you have a lift? I figured if I went up I'd also want to go out just as much if not a bit more. Stability wise I think it could use it.
Yup... 1.5” on the front and 2” on the back with 5+2 wheelsHey I meant to ask a while back, have you done any spacers being that you have a lift? I figured if I went up I'd also want to go out just as much if not a bit more. Stability wise I think it could use it.
Yeah I looked at their spacer package they look good. I was also thinking if and when I get wheels I thought of 4+3 offset. Thoughts?@RB3offroad is where I’d get them!
I need width! Most of my trails the width would help me a lot.
Some go that route...Yeah I looked at their spacer package they look good. I was also thinking if and when I get wheels I thought of 4+3 offset. Thoughts?
But......?Some go that route...
R u wider up front? Do u notice any difference in handling? Tipping point?@JenElio. I am sitting at 67in wide with no spacer's
Yeah I'm wider up front I plan on 1.5in spacer in the rear to square it upR u wider up front? Do u notice any difference in handling? Tipping point?
I only had my stock rims and tires for like the first 20 miles so I can't give you a true answerR u wider up front? Do u notice any difference in handling? Tipping point?
Point taken! Looks like I have a lot more reading up to do, thanks! I like to do my research be4 I make any changes. I might bug u a bit more later on down the road if u dont mind
That’s fine... I’m no expert by any means but might be a able to point you in the right direction.Point taken! Looks like I have a lot more reading up to do, thanks! I like to do my research be4 I make any changes. I might bug u a bit more later on down the road if u dont mind
