P700 Lightbar placement with factory roof?
bassadict69
30
20
Benton, La
I believe I know the answer to this, but is the factory roof going to force me to mount the lightbar somwhere besides at the top of the windshield like I see others mounted?
WagginTail
WagginTail
1,474
5,459
SC
I'm not sure but for me the higher up the better
Reactions: swsebek
swsebek
swsebek
2,854
5,829
pa
you will be able to mount it up high
bassadict69
30
20
Benton, La
I am bringing this back up...I had a tenant move out and he left behind a 51 or 52 inch lightbar he had mounted on his truck, so it has some brackets for that rather than the factory mounting brackets.
I have found the brackets they sell for mounting the lightbar down low on the windshield using the factory bolt locations. I would love to mount it high on the windshield...how can I do this with the factory hood that extends out and down a bit?
bassadict69
30
20
Benton, La
I am also needing some of the original L-type brackets that come on the lightbars...where might I find those?
bumperm
bumperm
1,851
6,655
Gardnerville, NV
I made the mounts for my 54" curved light bar, as I didn't much care for the ones I saw on eBay.
I can't argue with @DaddyDubbs, a high mounted light in rain, fog etc. is a non-starter. But, for all other more clear lighting situations, a high mounted light gives better useful range and better perspective. It is more labor intensive to install, though I think for sure worth it.
I did a write-up on the install, posted a couple of years ago. The 1/4 - 20 bolts go into rivet nuts in just one side of the roll cage corner gusset. The ones I saw elsewhere used longer bolts through both sides of that gusset, but I thought the added clamping pressure on the gusset not the best way to go. What I did works well, it's solid, doesn't vibrate, and holds adjustment.
20211017 112959
20210806 122901
Reactions: DaddyDubbs
DaddyDubbs
DaddyDubbs
13,874
129,615
Depending on current draw a relay may not be necessary, but it can't hurt and I like the added electrical protection. If you are not familiar here is a schematic on wiring a relay for lights.
Relay Wire
