Lighted Switch wiring correction info.
63,515
We have become aware that some of our lighted headlight retrofit switches may be incorrectly wired.
Here will give some details on how to inspect and check your connector.
This is the item in question - Lighted Headlight Switch Retrofit for Honda Pioneer 1000 - Plug-n-Play
Notice: There is no risk or concern regarding the issues listed here.
The below image IS CORRECT.
This is how the connector should be wired. Any differences will lead to the switch partley working, reversed, or not working at all.
We are mostly questioning the yellow and blue wire location. The black and white/black are correct on all switches.
1710442345628
Now we will discuss how to correct this.
Identify the wire that needs to be removed. Here we will work with the yellow wire in the below image.
To do this, take your finger and hold it like shown.
MWtLtCtAMqWEwMFhTY5vAw512 h911 s no gmauthuser0
Next, we want to push the finger holding the silver clip down. This will release the connector. Then give the wire a pull.
Tl2qFvzXtP ssfnKE2N9kw512 h911 s no gmauthuser0
The direction the fingers need to go. 2 are marked for reference.
SfkrpI9rUq7S6cZdrarZ0w512 h911 s no gmauthuser0
Finally, reinstall the wires per this layout
1710442345628
If you wish to do this yourself you are more than welcome.
Otherwise, contact HondaSxS to for a return shipping label. we will get it fixed and returned ASAP.
Thanks.
Similar threads
Replies
Views
24
Replies
Views
83
