Lo showing on voltmeter and voltage is fine
gobblerhuntr
gobblerhuntr
17
50
TN
There is more to it. Push and hold it.
You sir are my new hero! I just thought I pushed and held it long enough the other night. Sure nuff if you hold it long enough it will let you set a low and hi limit for whatever reason. I set the low at 11.5 and high at 17. We will see what happens. Hopefully that helps some other newbie that doesn’t know.
John Mc
78
178
Vermont
11.5 is seriously low for a 12 V battery: for a flooded lead acid battery at rest, 12.6+ is full and 12.2 volts is a 50% state of discharge. (AGM batteries tend to run 0.1 - 0.2 V higher) You really don't want to run them below 50% state of charge if you can avoid it. The deeper you cycle them, the more it shortens their life. 17 volts is high enough to damage the battery.
gobblerhuntr
gobblerhuntr
17
50
TN
I agree with you. But I don’t want a Lo or Hi message popping up. If the battery is sluggish starting I will jump right on it and find out why. And I prolly need to adjust the hi setting to 15 or so. It shouldn’t charge more than 14.5 or so. I’ll play with it and get it dialed in.
Reactions: Remington and TxDoc
63,409
Lol.. I knew it was something like that.
DRZRon1
DRZRon1
841
2,687
PA
it has officially turned into an engineering project - lol
gobblerhuntr
gobblerhuntr
17
50
TN
lol. That’s what Ido for a living.
  • Haha
Reactions: CID
DRZRon1
DRZRon1
841
2,687
PA
I hear ya, I’ve done controls/plc engineering forever, just got a 450hp VFAC drive started up, so last thing I want is basic electrical issues, our mantra at work is always “don’t make an engineering project out of it” - engineers take too long and complicate it - lol
  • Haha
Reactions: Scoop and CID
