Looking for lower A-arm and lower radius rod recommendations
K9Paco
K9Paco
629
2,225
Lake Charles, La
  1. Talon X LV
Twins!
F436678D FD08 4946 875F C45B7F3E50E4
108,184
The @SuperATV ones are nice. Beat the $hit out if them the last few years. So far so good!
08AFB737 FC2C 490C AC1F 0A27B7528694
Vondy
Vondy
1,414
9,138
Houston,OH
I run L&W front and rear. They have been tough but installed my second set of bushings in the rear radius rods. I just installed AJK Radius rods and they are very nice and seem to have much better bushings.
highpocket74
highpocket74
1,850
5,915
Kinder, Louisiana
www.10-80dirtsports.com
I'm considering designing my own radius rods now. I've located a source for rod ends. First ones may be straight but with thick wall DOM tube. I'll look into this and see. The good thing is my local shop now has a tubing bender so whatever I can dream up, they can make! That would come later with a high clearance design. A-arms are a little more complicated so not sure if I want to even touch that at this time. But it will be fermenting in the back of my mind.
I like the beam shape of the SuperATV rods.
ScottJ24
Cresson, TX
DragonFire makes some nice Radius Rods out of 1.25 DOM. I am putting a set of them on my car. We'll see how well they work.
906UP
906UP
13,200
123,389
da Yoop
I put SATV rad rods on mine (same as Remi's), for the front I went with L&W.
gparks
gparks
1,183
14,702
Asheville NC
  1. Talon X4 LV
How long did the first set last? I just installed them on my talonx-4 was wondering if I should buy a spare set.
highpocket74
highpocket74
1,850
5,915
Kinder, Louisiana
Since I am a retailer, I had a set of lower radius rods built to my dimensions and specs to see how they work and if I want to sell them on the website. These are for my Talon X2 model.
They look excellent and I'm hoping to install over the Thanksgiving holiday. Built from 1-1/2" OD 7075 aluminum with chromoly heim joints.
Radius rods
Radius rods ends
SLOWPOKE693
SLOWPOKE693
1,657
6,413
Somewhere in Texas
Do yourself a favor and use 5/8 heims at all 4 locations and use bushings to reduce the hole to fit the stock bolts. I used to kill 1/2 heims in my Raceco radius rods in two races before moving up to the 5/8 Raceco setup that has been trouble free ever since. Also, name brand Teflon lined heims are what you need to use. The China "heat treated cromo" heims most off road vendors sell are junk and will loosen up in a few rides. They are no better than tractor link heims
Reactions: ToddACimer
highpocket74
highpocket74
1,850
5,915
Kinder, Louisiana
Noted Slowpoke.
I think these are 3/4" heims but will have to look back at what I sent the builder.
I made an error and did not realize the outer side was a larger diameter shoulder bolt. Tried to install these yesterday and it was a no go only because of that. Contacted the builder and they are working on correcting this for me.
SLOWPOKE693
SLOWPOKE693
1,657
6,413
Somewhere in Texas
Noted Slowpoke.
I messed up the sizes, you are correct. The small heims are 5/8 and the big ones are 3/4. Use 3/4 all the way around with reducer bushings on the frame side.
