Talon Main Power Cable to Winch Circuit Protection ?
Dug2024
Dug2024
"Super Chicken"
37
92
West Georgia
Installing a winch on my X. Looking things over, including Honda's installation instructions, I see no circuit protection device for the cable that attaches to the start solenoid in the battery box. Am I missing something? Shouldn't that cable have some type of circuit breaker in line? If it were to short out, or the winch were to overload the circuit, it could do damage, or worse catch fire.
7,184
27,682
This is correct, you need to add some type of circuit protection. Honda only ran the wire.
Dug2024
Dug2024
"Super Chicken"
37
92
West Georgia
I wonder how many have been installed without a circuit breaker.. The Honda instructions specifically show connecting the wire directly to the start relay.. This is what I came up with.. of course I will insulate it well.
20200211 190004
906UP
906UP
13,205
123,480
da Yoop
What size circuit breaker did you use?
I've installed 100's of Warn winches with power coming directly off the hot post of the starter solenoid and never had any issues.
Every Pioneer and atv I've ever done regardless of winch brand has been installed this way.
Dug2024
Dug2024
"Super Chicken"
37
92
West Georgia
I just don't like the idea of the circuit not being protected. Piece of mind for me.
Reactions: 906UP
906UP
906UP
13,205
123,480
da Yoop
I'm using the Honda run cable to connect to the isolater, the winch & all other accessories are run off the aux battery
Reactions: Mudwing and Dug2024
JerrySwisher
9
Bloomsburg PA
Is the negative coming from back from honda already hooked up.. seen videos saying when using the leads on my talon x they hooked the positive and negative in battery box. Mine only seems to have a positive there and both up front. Thx in advance
906UP
906UP
13,205
123,480
da Yoop
Yes, at least on mine it was. A quick check with an ohm meter will let you know for sure.
Pretty sure the ground is already hooked up and the positive is not.
Makes no sense to have a powered hot wire hanging in the breeze not being used. Whereas a ground wouldn't hurt anything.
JerrySwisher
9
Bloomsburg PA
Thx for reply.
ToolTime
ToolTime
38
99
Oregon
Most of our winches will draw between 150-250 amps at full load, that’s a pretty big circuit breaker.
Doogle
Doogle
186
249
Surprise,Az Cincinnati,OH
I may be wrong, but I don't know of any car, truck, or motorcycle that has protection between the battery and the starter relay/solenoid. I think if Warn thought it was necessary, they would include protection in their kits.
Reactions: Boundertom
42,130
Out of the winches I've installed over the years, the one currently on my 700 is the only one that came with a breaker. And a few here told me not to install it, as it seems they tend to kick off at the worst possible time...IE during heavy winching, when you need it the most.
Reactions: Doogle
11,385
84,919
I like the waterproof switched circuit breakers. Convenient to cut power off when working on the circuit. Have a Bussman brand 300 amp
99DA483D 6AFF 46BB 9BEA 027CD12FE2A9
Reactions: 906UP
bjniceguy
322
431
Iowa
i agree with putting a break similar to Mudder and mountng in Battery Box where easy to get to in case need to reset. I originally mounted one up under dash where out of way for winch, but when tripped it, had to tear car half apart out on trail to reset it. Just saying, Think ahead
Reactions: 906UP
