P1000m5 Marine's Build
Marine660
246
244
I am putting together the list of parts and wanted to poll everyone on their thoughts, opinions, and experiences with these parts.
1.) trail armor full skids
2.) STI roctanes (28's or 30's)
3.) STI bead locks (what offset)
4.) warn 4500 winch & KFI winch mount
5.) 2" strong made lift (only if 30's)
6.) spod switches
My riding is as little mud as possible, technical rock climbing some, and trail riding.
I appreciate your feedback while I save my money up.
266,449
6.) spod switches
1.) trail armor full skids -Those should do the trick I like mine
2.) STI roctanes (28's or 30's) - Ran Roctanes on my last 3 SXS not a flat yet. love em
3.) STI bead locks (what offset) - 5+2 offset is close to OEM
4.) warn 4500 winch & KFI winch mount - WARN 4500 is good or you can save $300 and get a Superwinch Terra 45 same performance
5.) 2" strong made lift (only if 30's) - Mine mounted easily didn't affect the ride as far as I can tell
6.) spod switches - what ever flips your switch :)
Serial_Fordicator
38
6.) spod switches
I'm selling my strong made lift only been on a few rides. I cant fit the tires I want. Pm me and I'll save you about 80 bucks.
Marine660
246
244
I really appreciate it, however I was planning on getting it to allow me to run 30" roctanes. Given that Jackel is having trouble with this setup (roctanes & 2" lift) having enough clearance I am not as interested any longer in lifting.
I am going to run 28" roctanes and see if that works without a lift...the lower the CG the better in my opinon.
Reactions: Serial_Fordicator
fordraptor
fordraptor
WV
Warn 4500 and STI HD5 beadlocks.
12465882 10204233982964790 8286892386009345208 o
28 inch tires
Reactions: Tot
266,449
Am I hallucinating or are your front tires 1" shorter than the rear? Looks like 27" on front and 28" on rear? :rolleyes:
fordraptor
fordraptor
WV
Hallucinating, 28in all around. Although, at that angle??
fordraptor
fordraptor
WV
Did you add the led headlights or did it come that way? My 1000 3 EPS came with halogens.
Very nice by the way.
Ordered. My dealer let me have any accessories at cost,no labor, so took advantage.
fordraptor
fordraptor
WV
Marine660, does not rub turning. Waiting to see what happens when compressed. My guess would be they are fine. Rocktanes do run larger by about 3/4in
fordraptor
fordraptor
WV
What I have learned from my short time on this site. 1. Lots of good info. 2. I'm no photographer!!!!!!!!!!!
Reactions: JACKAL and joeymt33
Similar threads
