P500 Maxxis 2.0 bh 26x9x12 still clear wheel well?
Ketch
Ketch
21
82
Austin
Like many, I am wanting to upgrade my tire size. I also need it to still fit in my pick up bed for transport. Does anyone have experience with whether the 26 inch maxxis by will still clear the wheel wells. I understand that the rear wheels 26x11x12 will be wider but I believe only the front needs to fit…please advise.
Ketch
Ketch
21
82
Austin
Stock rims. Namely cause I don’t know the advantages/disadvantages of 14” rims versus 12”. Wasn’t thinking spacers as the aforementioned tires has the 5+2 offset.
158,808
14" rims give you some more tire choices but the ride will be rougher than with 12's. Not as much sidewall available for cushioning. I had 26x9's on the front of mine with 5+2's. Built some ramps so I could drive over the wheel wells in a 2012 Sierra. Ended up not needing the ramps, tires just squeezed through.
CamoP500
89
177
Lake Vermilion
26X9X12 kenda bear claws on stock rims no spacers fit through the wheel wells on a chevy and Toyota. They rub a little but not a big deal.
HiFive
HiFive
624
2,535
West Central Fl.
was this with a bed liner or without a bed liner in the Toyota. I'm assuming it was a Toyota Tundra?
CamoP500
89
177
Lake Vermilion
Tundra with a bed liner. The Chev has a bed liner also. It squeezes through but the tires don't ride up on the wheel wells.
Reactions: HiFive
