P500 Mighty P500 Build
Lee's Garage Index:
Forgot to leave a blank thread for the index so I'm hijacking the intro.
Index
  • New vehicle prep #2, 3, 5, 6, 7, 8, 9, 10, 11
  • Planning and other thinking #12
  • Tire pressure #16
  • Winch / plow mount #17, 18
  • Water sealing around the pedals #19
  • After market tires (not yet)
  • Windshield #23
  • Rack storage #21
  • Top and back #22
  • Navigation: mounting a tablet to the ROPS #29
  • Front locker install #31, field testing #32
208,028
Tires:
On my outing to test the front locker I pinched a rear tire.
I was riding with 2 experienced p1k pilots so I dropped the tire pressure to 6psi to gain a little traction.
By the time I got home one of the rears was noticeably low on air.
I could see where the pinch was but it was not bad, just a slow leak.
So I tried to patch it on the inside.
Kind of a pain as the side walls are curved and fairly stiff.
The patch leaked or there was another leak I did not see, the tire went down ever so slowly.
When my wife saw this she told me to quit messing with it and order new tires.
If I would have known it was going to be that easy I would have backed over a screwdriver the 1st week I had the thing.
I did a quick survey to see what size and tire I wanted.
Then I ignored this and got what I knew I would be getting anyways.
I know, I've used this picture a few times already.
But the tires look good don't they?
That must be one bad A mud puddle! HA!
Reactions: Mudder
The Green Goat
The Green Goat
1,782
12,691
Ohio
I'm glad I'm not the only one over here scratching my head wondering how he managed to do that...
lee
lee
Village Idiot
2,346
13,179
Springfield Ohio
So, although I should know better I plowed out from the snowpocalypse using my synthetic winch rope and a hawse fairlead.
A) 5” of snow is not a snowpocalypse.
B) I’m a dumb ass.
As one would expect the rope broke, fortunately right as I was finishing.
Interestingly the rope was having an issue an issue with the center of the spool being crushed.
In the picture below you can see the V shape of the rope on the spool.
So I looked at some of the solutions that that the winch makers have out there.
$30~$40 is not bad.
But the reviews point out all sorts of issues.
Looking at YouTube I found this.
It seams to avoid some of the pitfalls and it’s cheap.
316822 1d3ae6e3892245c648d67972fd86391e
Bought a cheap tow strap from harbor freight, cheapest on they had was $12 and it will make 2 straps.
Used duct tape to attach the strap to the drum.
Spooled the strap on to the drum.
Also I switched out the hawse for the roller fairlead that came with the winch (the one with the big roller on bottom - looks like it has a fat lip).
The Warn/Honda plow has a thing to keep the hook / thimble out of the fairlead.
I folded the strap in thirds and it fit in the little catch thing.
Made another pass around the property and this set up worked well.
So far so good.
159,009
B) I’m a dumb ass.
$30~$40 is not bad.
So far so good.
Yeah, I started switching over to the roller fairlead after breaking my rope plowing. I'll use the hawse on the trails though.
The Green Goat
The Green Goat
1,782
12,691
Ohio
FYI, KFI sells a plow strap for like $30, if you don't want to mess with making your own.
