P1000 Most Quiet Muffler
cnaught
12
21
Broward County, Florida
I just bought a slightly used 2020 Pioneer 1000-5. It's much louder than I had expected. It looks like it has an aftermarket Muffler on it "HMF". I am not looking for a high performance muffler, but the most quiet option available, as I will be using it to ride hunting trails between 5-25 MPH tops. Any suggestions?
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Stock will probably be best.
find a used take off?
tdhanses
tdhanses
1,044
3,553
Kansas
Google HMF quiet core insert, costs around $30, makes a big difference but still not as quiet as stock but not far from it. My biggest issue with the HMF is the back pressure noise was super loud reflecting off the roof, this helped.
tdhanses
tdhanses
1,044
3,553
Kansas
Thanks. Is there something that I can add to the stock muffler to make it even more quiet?
Not that I’m aware of, also note the stock muffler will run much hotter due to the built in catalytic converter.
Reactions: Rick53 and Lady01
tdhanses
tdhanses
1,044
3,553
Kansas
Is that an issue? Will the riders in the back seat be affected by more heat from the stock muffler than the HMF?
Yes they will but it’ll still get hot back there with either option, don’t know if i’d say its an issue, depends on the people really.
107,306
It surprises me if no one makes a muffler that is more quiet than the stock?
Cuz the stock is quiet! Its a SXS, Not a Jeep/Bronco lol
Also if u can quiet the stocker, you will loose power.
So, you got pics of this machine and muffler in question? Are u sure u dont already have the HMF qs as in quiet? Its noisy also
cnaught
12
21
Here you go!
241904807 153733060259296 9068623830284942212 n
241978591 2063049857177282 6313241992621835226 n
tdhanses
tdhanses
1,044
3,553
Kansas
I’d start with the insert, might make you happy. Otherwise you could sell that exhaust in about 2 seconds if you wanted to, highly desirable and not quick to get unless things have changed recently.
107,306
I think that insert is for the NON qs to make it that. He’ ll Have to determine if he has the QS or not it was hard to tell in his pics. Should be some numbers on there indicating it I’m not sure what they are though. You may have to check on their website to see how thats determined. But even that, if he thinks the stock exhaust is too loud he certainly will not like the QS. It’s definitely louder. I like the sound of mine but it’s definitely louder than stock
tdhanses
tdhanses
1,044
3,553
Kansas
It fits both I have the QS and it fits.
Good comparison of stock vs HMF, db’s dont seem much different but tone is deeper.
And HMF QS
107,306
Oh I bet it fits. Because they both look exactly the same. It’s just the guts that are different. I’m just curious if it is designed for the QS? Do u have a link and cost?
Do you an HMF QS and this adaptor? I had a non QS and now the QS.
AFE5DF4D A570 4AB5 9EE2 5123EA95BD0F
Best pic of the rear i got on my phone without deer blood and guts in the back.
tdhanses
tdhanses
1,044
3,553
Kansas
Yup I have the QS and this adapter, it helps with the deep engine braking drone and when cruising at a constant speed its a tad quieter, you remove the spark arrestor screen and then it slides in and you cn reinstall the screen and tip.
I do believe you have to install the spark arrest to get a good tight fit.
107,306
Not bad for 34$
still wont be quieter than the sock one so he wont be happy 🤣
bumperm
bumperm
1,851
6,656
Gardnerville, NV
If you shove a potato in the end of the pipe, it'll quiet it right down.
(Helpful hint: carry several, not sure how long it'll last.)
  • Haha
Reactions: Remington
cnaught
12
21
Not bad for 34$
Ha! My primary purpose is riding in the woods and getting as close to game as possible. I have also have an electric sxs, which I also love, but it has a limited range and limited clearance. The only noise it makes is the tires crunching whatever they roll over. In 2018 Honda showed a prototype of an electric pioneer with hot swappable lithium packs. There are some other companies like Volvon that plan on releasing lithium sxs in the next few years, but until something like that comes available, I'll be scaring away more game than I wish.
BigOL3
BigOL3
2,994
8,919
Walk in the last 1/4 mile.
