Talon Mozingo 1000x4
Travis_Mozingo
Travis_Mozingo
Holton, In.
  1. Talon X4
Had a blast building this machine.
Rockford front end with an radio
2- kicker amps
2- 6.5 kicker ps speakers in custom under dash enxlosures
2- kicker 8 in kicker ps speakers in
rockville tower pods
10 in kicker comprt under passenger seat
Custom front bumper with sat 4500 winch
Custom rock sliders
Modified lock and ride cooler to lock in bed
Second 30ah battery
Underglow rock lights
31x10.5 r 15 mickey thompson baja claws
Xtc turning signals with smoked front markers
Direction 2 windshield modified to a full flip up
1122191612 HDR 1122191612a 1109191630 HDR 1104191709 HDR 1103191530 1109192002
Farmer
Farmer
2,850
16,380
Southern MO
Looking good and welcome to the club!
GregMorenoAZ
GregMorenoAZ
17
Yuma Az
Great stuff you got there...
Please advise on how & what did you
Modified to the lock and ride cooler to lock in bed
Travis_Mozingo
Travis_Mozingo
Holton, In.
  1. Talon X4
I made a custom plate for the back prongs of the Polaris cooler to slide in. Took the Lock & Ride clamps off Each corner and mounted one in the center. I did have to drill a three-quarter inch diameter hole in the bed for the Lock & Ride clamp to slide into. But it all come out perfect. this was a cooler out of a 900 Polaris. It's the style with the double opening lid
Reactions: Sheetmetalfab
jasond
jasond
220
350
Indiana
@Travis_Mozingo I've also got the Rockford head unit in my machine. I ran into a bit of a real estate issue and ended up getting this 6-switch panel for the lower cubby area. I bought it from a guy named Rick Bentley (he owns a custom fabrication shop out west and I happened to stumble on a picture of it in his machine in an Instagram post).
You'll probably notice the small gap at the bottom of my panel and that's not a poor design issue. I added the volt meter and modified the panel so I could also have it. As a result, it creates added tension on top and causes the gap at the bottom so I wanted to call that out.
It's an idea if you're needing a switch panel with your head unit setup:
IMG 2454 IMG 2458
  • Talon Lower Cubby Switch Panel.zip
JONNY P
JONNY P
10
23
What brand is the hard case box in the trunk of Talon? Looks really sharp!
Please post link to hard box case.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
It’s the Polaris oem accessory lock and ride cooler. (Per OP’s post #1)
