Talon My99svt's Talon
my99svt submitted a new Garage Item:
My99svt's Talon
Just creating a thread for my Talon build. It won't be in a particular order. So far I've added:
hondasxs.com key-on accessory: KEY ON POWER Harness for Honda Pioneer 1000, 700, 500, and Talon 1000.
hondasxs.com seat belt bypass: Harness accessory seatbelt bypass kit - Honda Pioneer, Honda Talon
Rigid Red Chaser light: Chase
Switch Pro modular switch controller: SP-9100 Bezel Style 8-Switch Panel Power System with Concealed Mounting Hardware
Pro Armor harnesses: 4 Point 3 Harness with Sewn in Pads | Pro Armor
Honda accessory center storage bag: Center Storage Bag
Read more about this showcase item here...
Vondy
Vondy
1,399
8,948
Houston,OH
  1. Talon X4
Yes, it is expensive, but the labor I saved not wiring all the switches was worth it. And I had credit card points on amazon so I didn't have to come out of pocket as much.
I saw that about the winch, But I planned on installing a Warn Axon 5500, and will use what comes with it. I've had issues with the switches I've used for the winch on my pioneer.
I mounted the brain by the battery, comes with 2' power cable to connect to battery. See pic for brain location next to airbox.
Thanks, when I first looked at the pic I thought i was under the hood. I'll probably order this as well. Thanks for the help.
Reactions: sharp
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
Once I get closer to one in person, I'll take a look for it.
Once I can take it out of my garage to really look around it, I'm sure I'll find it. My motor home is blocking it so I can't get it out of the garage. I'm pulling it out tomorrow to go to Mulberry Mountain for it's first ride.
my99svt
my99svt
1,267
5,248
You could probably mount it under the hood and use the winch wiring for power. I thought about it but by the air filter was easier access for me.
Reactions: sharp
Loving the idea of the switch pro. I a little pricey at $550, but sure would be a clean and easy install. It says that it can't be used as a winch control, any idea why? I understand not running the winch power thru it, but curious as to why the controls can't. Would be great to be able to put a winch in and winch out momentary button on it.
Did you run new power wires back to the battery or just hook to what honda provided for the winch?
Between OTRATTW switches, connectors, wire, solder, and PDM, I bet I am more than $550 for 8 switches before you were to even consider time....
This will be my 4th rodeo on wiring everything up. It’s a PAIN, as soon as all the early adopters like @my99svt figure out all the quirks and make sure there aren’t any major issues, and a few more aftermarket accessories are available I’ll probably be adding on to the stable.
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
So much truth to that!
The price of $550 is scary because it is all spent at once.
When you use switches, it's $75 here, $130 there, another $50 here etc. It adds up. We just don't recognize it as much. Anyone asks, we would say we only have $200 in it. But in reality it is much much more.
Sandfreak
23
Oregon
Looking good. Can't beat the Switch Pro. Have them in both my 18 X3's.
20180406 124748
MFG
MFG
191
293
East Texas
Reactions: sharp
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
I really like your dash layout! What hub adaptor did you use for the steering wheel? I hate my stocker.
The steering wheel you see was not a Talon.
We have a bunch of threads with everything in it for shopping.
P1000 - Steering wheel
That is one of the latest threads with lots of info.
Reactions: CumminsPusher
