P500 Need a rearview mirror
Snek
Snek
“Member” huh huh
649
8,370
Saint Augustine FL
This one is “fine” for what I paid, depending on your expectations:
A04E37D2 1127 469F BE7A 8A2C604B5B96
duhmojo
duhmojo
32
45
Canada
If you need side mirrors as well (so you can view your wheels against obstacles) there's this Kolpin set:
The rear view will do, but I'm really only getting it for the sides and ideally a backup cam mirror mounted to the rear mirror (you're not going to find a rear cam mirror with a mounting bracket, you'll need a donor mirror). These sides are split as well. You can angle the lower different than the straight back uppers. They also fold in.
Just another suggestion. Good luck!
HiFive
HiFive
623
2,528
West Central Fl.
I have what duhmojo recommend works well. I don't use the rear view mirror much but, wife likes it. The koplin three mirror set is a good value. Bought mine at bass pro. The rear view mirror is large compared to OEM by Honda.
crewcabrob
crewcabrob
1,029
4,038
Omaha
I also bought the OEM Honda mirror and it’s terrible. I took it off last night prior to my trip to the National Forest. I will be going with side mirrors now.
Just need to find some that work with the soft doors I want to get at some time.
Rob
