P1000 Need Help Identifying
The Hunter
The Hunter
68
357
53
Kentucky
Can someone help me and tell me what brand these tie rods are. I bought my machine used. It’s a 2019 and I bought it in 2021. Theses tie rods are getting sloppy and I need new ones or should I replace back to stock or go to @SuperATV .
2866DC9E 8403 4C99 A273 57D84388E8B7
D512CFEF 9F11 4CE1 8EB1 280415748126
9A34A193 604D 43A4 BE0A 02A6AFB30C7C
  • Wow
Reactions: Remington
57,146
Can someone help me and tell me what brand these tie rods are. I bought my machine used. It’s a 2019 and I bought it in 2021. Theses tie rods are getting sloppy and I need new ones or should I replace back to stock or go to @SuperATV .View attachment 375427View attachment 375428View attachment 375430
Not sure on the brand but you could just replace the heims if you want to keep them. Just need some new JM10T FK heims:
1677095546764
Probably cheaper places but that was the first that popped up when I searched.
TripleB
TripleB
11,966
101,681
Caryville, Tennessee
The Hunter
The Hunter
68
357
53
Kentucky
Thanks @TripleB , I’ve read where the new ones are a lot stronger now. I’m going to try the new Heims and see how long they last and then might spring for the OEM. I’m not sure if I could just order the 2022 tie rods or if I would have to get the steering rods all the way to the rack. Not sure if the previous owner changed to run these Heims or just changed the tie rods for the Heims
The Hunter
The Hunter
68
357
53
Kentucky
Well I have figured out that my hd tie rods on my machine are made by turnkey. Also figured out that to install these you have to drill out your knuckle where the outer tie rods goes to get that big bolt through to hold the heim joint. I guess I’ll keep running it for now, I looked up new knuckles and tie rods on Ron Ayer’s and it’s cheaper to keep what I’ve got. Not sure why someone would put these on due to drilling out the knuckle seems a bad idea to me but I’m stuck with it. I’ll change the Heims and keep riding
Mopower58
Mopower58
CST is the Best!
71,288
652,822
Crystal Springs,Ms.
Good luck with that. No way to grease those huh? Did you check with C-Fab? Those look mighty similar.
The Hunter
The Hunter
68
357
53
Kentucky
Yeah no grease, C-fab’s uses bushings and these (turnkey) you drill your knuckle out to 5/8”. No way would I want to do that. The previous owner did though and I was thinking about changing to the 2022 tie rods but now I would need new knuckles also. I haven’t had and problems with these and turns out that the slack is the bolt that goes through the heim is wore and not the heim so I guess I’ll try to find and couple new bolts at TSC.
Mopower58
Mopower58
CST is the Best!
71,288
652,822
Crystal Springs,Ms.
I see, if you can find some, I would suggest grade 8 or more. They will be a harder material and wear out a little slower.
The Hunter
The Hunter
68
357
53
Kentucky
Thanks for the advice Mopower58. That’s what I’ll be looking for. The new tie rods was $196 before shipping and the new knuckles was $96 per side. So a couple of bolts and Heims will be a lot cheaper.
Mopower58
Mopower58
CST is the Best!
71,288
652,822
Crystal Springs,Ms.
You are welcome, cheaper is always good provided the quality is there. You might could drill and tap for grease fittings if possible.
