Talon Nerf bar installation help!
N
Neilsjoshn
21
133
Pennsylvania
Am I supposed to take off or cut the plastic? Any help would be great.
Reactions: sharp
Vondy
Vondy
1,399
8,948
Houston,OH
  1. Talon X4
Following, I have some coming as well.
I did see some brackets in front of rear wheel. On frame. Figured the rear mounted to them.
266,543
Should have the downloadable install instructions online with the accessories. But after checking, they are not linked to them like the Pioneer lineup.
N
Neilsjoshn
21
133
Pennsylvania
I got the
nerf bars
front rear aluminum bumpers
half windshield
rear view mirror
A arm guards
Trailing arm guards
Got them all installed no instructions it worked out.
Reactions: CumminsPusher
Bigblue1
77
92
NC
I got the
nerf bars
half windshield
rear view mirror
A arm guards
Trailing arm guards
How's the quality on the aluminum bumpers?
HondaTech
According to the instructions I have, the drivers and passengers side skid plates need trimmed. Apparently there is a scribe line on that part that should be used to guide your cut.
Reactions: sharp
320,493
Have to trim the skid plates?
Talonpalooza
Talonpalooza
122
237
Just the side plates that wrap around to under the doors.
I am confused. You have to trim the existing side plates to install nerf bars? The score line is on nerf bars or side plates?
HondaTech
The instructions aren't super great ill admit. Ill post them here so everyone can look.
It appears to me that there is a scribe line from the factory on the plastic skid plate that wraps under the side bar directly below the doors, you use that line to trim out for the nerf bars to mount.
  • nerfbarinstallinst..pdf
Reactions: sharp
N
Neilsjoshn
21
133
Pennsylvania
Got them on
2a587739b861b92e936f65f58e57e506
