P700 NEW CV AXLES
JIMVJ
22
65
FLORIDA
I HAVE A LOUD CLUNK NOISE AS I SHIFT THE UNIT INTO DRIVE . LEFT REAR I THINK IT MAY BE THE CV AXLE. WHAT BRAND DO YOU GUYS RECOMMEND AND HOW ABOUT THE BEARINGS TO BE REPLACED?
Neohio
Neohio
Beast of the East
13,345
64,898
Painesville Ohio
CV axles don't typically make noise while stationary. If the wheel isn't rotating, the CV axle isn't being moved to click/clank/clunk.
Superatv axles thru @Hondasxs are a common replacement.
Bearings are a bit more work, how comfortable are you in automotive repair?
Depending on age of the SXS, you may need a shop press to remove the old bearing.
If you remove the upright/knuckle and have issues, and competent auto shop will be able to remove them.
JIMVJ
22
65
FLORIDA
THE UNIT MAKES A CLUNK AS I PUT IT IN GEAR. IM NOT SURE AS TO WHAT IT IS. I MAY HAVE TO BRING IT IN AGAIN FOR THIS.
