New machine with milky sub trans oil
106,548
Ok @Jonpin
I did a generator maintenance today. It only has 75 run hours on it. You can see on the dipstick the milkiness from moisture and most likely assembly grease. 75 run hours is not very much. This will happen on the first couple oil changes on new units until all that grease and moisture from assembly finally works its way out as you changed the oil. Nothing to worry about.
IMG 0078
