New Turn Pro on P520. Troubleshooting
crewcabrob
crewcabrob
1,029
4,038
Omaha
Hi everyone,
i’ve been doing a build on my Honda pioneer P520 for the last week and a half. I’m just finishing up the turn signals this evening. All turn signals work except for the driver side front. It doesn’t matter if I use the turn signal switch or the hazard light switch, all the lights will work as normal except for the front driver side. Does anyone have any ideas on this issue?
Thank you,
Rob
Reactions: Buggyman
HondaTech
Have you tried swapping that light to another position?
Could just be a dead LED.
Reactions: Buggyman
crewcabrob
crewcabrob
1,029
4,038
Omaha
It’s actually three different LEDs on that side. So I would doubt that all three of them are bad. But I did keep swapping wires around to see if there was just one that might work.
Reactions: Buggyman
crewcabrob
crewcabrob
1,029
4,038
Omaha
Reactions: Buggyman
crewcabrob
crewcabrob
1,029
4,038
Omaha
I actually just solved my problem. For some reason the colors of the wires didn’t seem to match up. On the passenger side I connected the colored wire to the black wire for each LED and the white wire was connected to the white wire on each LED. It seems to be the exact opposite on the driver side. The black wire On the LED to the white wire and the white wire on the LED to the colored wire in the harness.
Reactions: Buggyman
crewcabrob
crewcabrob
1,029
4,038
Omaha
Thank you for your reply though and I appreciate you coming in to help.
Reactions: Buggyman
Buggyman
Buggyman
34,335
293,514
ne. ohio
View attachment 347123View attachment 347124I actually just solved my problem. For some reason the colors of the wires didn’t seem to match up. On the passenger side I connected the colored wire to the black wire for each LED and the white wire was connected to the white wire on each LED. It seems to be the exact opposite on the driver side. The black wire On the LED to the white wire and the white wire on the LED to the colored wire in the harness.
If you have any trouble in the future just Email Grant at turn pro. he responds very quick and can do most trouble shooting over the phone if you have a test light or meter. He is a very nice guy and fantastic customer service. I had a issue of my own doing and he made a complete custom main harness and shipped it to me in about a week at NO cost.
Similar threads
