P1000 Novice with a winch
Vikes79
Vikes79
SKOL!
10,884
105,611
South Dakota
  2. Talon X4 LV
Fortunately the 2022 Trail comes with a belly pan of sorts. It’s not metal but it seemed to work! :)
Yeah they do come with something that’s a bit better than a sheet of cardboard.
It’s an extremely common upgrade that also helps to reduce sticks and junk from coming up through the lower portions of the floor.
Most go the entire width and length of the rig, the oem only does parts of the middle.
NewHere2
NewHere2
Village Idiot In Training
35,700
303,720
High Plains of SD
$600 - $800 for a quality skid plate is a lot cheaper than taking someone to an ER.
StewB
StewB
667
3,090
Thank you all for your suggestions! I do have a strap but need to get a heavy duty pulley.
I’ll have to educate myself on winch usage before my next episode. I didn’t think about the load while paying out the cable causing heat.
Does it require a second battery? What about rope vs cable?
Having a winch is a good thing but not knowing anything about it makes it useless.
The pulley you need is called a snatch block. These straddle then attach around the cable/rope. Tractor Supply or Amazon are good sources.
You don't need a second battery for random winching. I use my winch to lift a plow blade. That's a lot of winching, so a second battery helps avoid heavy drain.
Search this board and you'll find people's opinions re synthetic rope v. wire cable. There are pros and cons. For example, wire line can snap and slingshot at you; synthetic will not. Synthetic must avoid abrasion and sharp edges.
I use wire. My primary use is plowing, which wears the last 4 feet of the cable. About every other year I cut off the frayed end and use three u-bolt clamps to reattach.
Watch yoootoob how to videos for safety and other tips.
Sometimes you should use a remote for safety purposes - can keep you out of harm's way.
Good luck.
TripleB
TripleB
11,722
99,573
Caryville, Tennessee
Well, now, that explains why @TripleB is such an expert at it!
We never would've made it home Monday without winches. Ran up on this widowmaker at the end of the trail on the way home. Hill was too rough and steep to back out and too narrow to turn around. Had to winch the front ends up the bank just to get the machine to wedge under the tree. Then power through underneath the tree and praying the tree didn't break on off.
VideoCapture 20240117 151100
VideoCapture 20240117 151114
KevP700-4
KevP700-4
249
609
Northern MI
Free spool pay out of the cable saves the battery as said, also much faster. Keep your winch spool lubed, just a few drops of oil at ends of the spool each year at annual maint., Keep engine revs up while using the winch multiple times so to keep your battery charging to the max available. Installing a winch battery is a smart move, but it too gets tired after multiple runs. Might want to occasionally run a oily rag over the extended cable to keep it from rusting and binding on the spool. Never pull the cable fully out, always keep two or three wraps on the spool before putting the winch to work. Watch those cables/ropes they do break once in a while.
Yup, get a tree strap, snatch block and a 30' strap/rope/cable to extend your 50' spool cable reach, the tree you need to pull from is not always within 45' of your winch spool, ask me how i know. These also help when pulling a friend out of trouble. Check Harbor Freight for basic emergency supplies.
Warn Corp. has videos and lots of great advice on winch usage.
PapasTrail
PapasTrail
17
52
Cabot AR
Thanks for all the great responses! I bought a snatch block, a tree saver, a sling strap, and a couple of shackles from Harbor Freight!
I replaced the cable with a synthetic rope because I damaged the cable when I bent the fairlead… hopefully I’ll never have to use this stuff but it’s like having a handgun. Better to have it and not need it than need it and not have it!
Next on my list is an entrenching tool. I really wish this P1000 had more storage compartments!
KevP700-4
KevP700-4
249
609
Northern MI
Papas Trail, you might want to pickup a cheap tool bag at HF to hold all the new stuff. Doesn’t need to be large. We have one and just strap it in back when we go riding. Ours will also fit under the front hood if needed, or in the rear footwells for the 700-4.
StewB
StewB
667
3,090
Mesh storage bags can be held up under the roof with ratchet straps.
I posted this photo on another thread but thought I would add it here.
One of my mesh storage bags can be seen. It holds a lot of stuff and you can still wash your machine without having to unload the storage.
1705871939535 png
