Oil temp light not working
sugarray
sugarray
Is this a game show?
661
1,257
WV
Ok then I dont think 15 ohms is correct. I would expect 1k ohms or more.
So when I touch the tip and then nut I get 14 on the green scale, which I guess is 14,000?
This is on RX1K. Still nothing on the RX10
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
Ok what does it read now after you zeroed on RX1
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
Ok 14k ohms
Anyway possible to start it and let it idle while keeping meter probes connected? Would like to see if resistance changes when oil warms up .
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
This sensor doenst sound like a switch, it sounds like it sends a resistance info to the e m that triggers the light
Reactions: sharp
sugarray
sugarray
661
1,257
WV
I can’t let it idle. It’s in the garage, which has kid’s bedroom above it. I can do that tomorrow.
From what I’ve read, seems like the problem is in the rectifier or cdi.
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
Am I correct that the lite does not come on for a couple seconds when the key is cycled?
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
Have you changed the sensor already?
Reactions: sharp
sugarray
sugarray
661
1,257
WV
You are correct
Yes, I have changed the sensor
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
You are correct
If you still have the old one ,compare the readings. And if they are similar, put the old sensor in water and heat it up. The resistance should change with temp change.
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,145
27,191
Somereset, Texas
No ECM output would be my rhought.
Reactions: sharp
sugarray
sugarray
661
1,257
WV
As the temp came up the resistance decreased. Down to 4-5000 by the time I came in.
I don’t have the old sensor
Reactions: sharp
sugarray
sugarray
661
1,257
WV
Anyone have the wire diagram or manual? How to see that the CDI or rectifier are good or bad?
Reactions: sharp
sugarray
sugarray
661
1,257
WV
So, with help from Honda Tech, this model doesn't have the light check with key on. So, we were chasing our tails. I've got it buttoned back up and going to get some tires to get the kids riding!!
Similar threads
