Oil type for 2016 Pioneer 1000-5 deluxe
WagBag
WagBag
10
48
Anthem, AZ
Hi, I’m new to this forum and new to the SxS world. I recently bought a 2016 Pioneer 1000-5 deluxe and trying to figure out a few things for maintenance.
I’m wondering if I should use what the owners manual recommends for oil or is it better, since it’s older, to use a synthetic oil with the same weight? It has around 4,600 miles.
Also, any recommendations for oil change kits on Amazon?
Thanks
NTCPrezJB
NTCPrezJB
President of #NTC
101,966
910,893
Canton, OH
Oil and tires are going to get you many opinions. You need to use a wet clutch oil but otherwise it’s really up to your preference…and many will swear by dino oil with many others swearing by synthetic.
POIDH
RITFC
#NTC
906UP
906UP
13,203
123,406
da Yoop
Since you asked and just my opinion......
I only use OEM filters, I usually order them 3 or 4 at a time so I always have some on hand. For oil I use Shell Rotella T6 synthetic, 5W-40, it's JASO MA2 certified for a wet clutch
Regardless of what flavor you choose make sure it's JASO MA or MA2 spec
108,187
Ooooo all this ☝️ ☝️☝️☝️☝️☝️
is all you need to know! Been using the exact in my 16’ P1 since it was new and she perrrrrrs like she has the cat scratch fever!!!
JenElio
JenElio
65,864
614,225
Loxahatchee, florida
108,187
Welcome from another prisoner of the Radical Leftist Run Michigan!
Rule #4 is pics when you join and first post! Weve answered alot for you already, do us a solid and post em up! Pics Or It Didnt Happen!
So you say you have a 16’ the lingering question is did the previous owner tell u if he got all the campaign updates done, especially the clutch one ?
WagBag
WagBag
10
48
Anthem, AZ
Nothing was said about any updates. How do I check for these?
Not sure what pics to post or rule #4?
108,187
Use the search up top for 16’ recalls/updates and read on. You can call your local Honda dealer with your vin and they can tell u whats been done. There is also a way to check to see if the clutch update was done. It was a campaign that has expired tho.
As for pics, any pics of your machine will do! Its proof u have a rig and it helps us understand what you have. Plus were imagination deficient so Post em up!
heres a way to see if u have had the clutch update on that rig. Again the search bar up too is your friend.
9A6BB3D5 AB0C 49F0 8DC4 87680E62B97A
WagBag
WagBag
10
48
Anthem, AZ
Will do (pics). Thanks again!
WagBag
WagBag
10
48
Anthem, AZ
JenElio
JenElio
65,864
614,225
