Outdoor kitchen countertops?
03mossy
03mossy
275
1,080
MN
  2. Other Brand
I built an outdoor kitchen about 5 years ago. We use it all the time but the tops are not holding up. I used 1” cedar for the tops thinking it was the best choice to be out in the elements. The kitchen is covered but rain and moisture still get in there when it’s windy. The cedar has warped and looks like s*** from all the grease splatter from the blackstone. I want to redo them this weekend but not sure what to use. Oak? Laminate? Butcher block? Concrete? There is a used restaurant supply place by me that has stainless countertops. Those would work but would take some fabrication.
Figure with the wide range of knowledge here someone may have the answer!
Thanks
Pics from when it was first built.
IMG 7078
IMG 7076
107,397
My customers that have once use Some sort of hard surface, like concrete, granite, ect. You can try compost decking but it might melt getting heat from your cook top. If you do any type of wood, you would have to do a poly urethane on it and lots and lots of coats and will probably have to reapply it yearly to keep up its durability. Not sure about u, but I wouldn't want to do that. Do the job one time with a hard surface. Buy once Cry once.
266,553
I built an outdoor kitchen about 5 years ago. We use it all the time but the tops are not holding up. I used 1” cedar for the tops thinking it was the best choice to be out in the elements. The kitchen is covered but rain and moisture still get in there when it’s windy. The cedar has warped and looks like s*** from all the grease splatter from the blackstone. I’m want to redo them this weekend but not sure what to use. Oak? Laminate? Butcher block? Concrete? There a used restaurant supply place by me that has stainless countertops. Those would work but would take some fabrication.
Figure with the wide range of knowledge her someone may have the answer!
Thanks
Pic from when it was first built.
View attachment 425646View attachment 425647
Might look into Corian countertops by DuPont, durable and readily available at LOWE'S , Home Depot, etc.
JenElio
JenElio
65,157
609,730
Loxahatchee, florida
Thanks
Looks nice 👍
For outdoors like that I'd recommend a man-made material. Quartz, or Corian would probably be best. Anything else and you'll have to seal/treat it ever so often. If you're set on wood, Teak would be my go to, again.....have to oil it now n then but it'll last a lifetime.
107,397
So basically a hard surface of some sort.
npaden
npaden
47
267
Lubbock, Texas
I did my own concrete countertops and they turned out decent.
Followed the Michael Builds channel on YouTube.
He has a bunch of variations also.
Was a reasonably easy and fun project.
IMG 0953
IMG 0978
It's coming up on 5 years and they are holding up really well.
Rayger143
Rayger143
2,753
23,852
Winfield, BC Canada
Thanks
My neighbor made a countertop with the left over composite decking from his deck and it has stood up well.
66,830
Looks nice 👍
Corian stains pretty easily doesn't it? We never see them anymore around here. I recall going to a house and they looked terrible after a yr or 2. I'd do concrete personally
JenElio
JenElio
65,157
609,730
It can stain, and scratches also, but it's pretty simple to bring it back to new as needed.
03mossy
03mossy
275
1,080
MN
  2. Other Brand
Appreciate all the replies! Back when I first built this I had planned on doing a concrete top. Plans changed last minute when I decided to do the cedar. I think I am going to do the concrete. Hopefully I’ll be able to post back with some good pics by Sunday!
Coeus
Coeus
Major General
59,443
594,152
Signal Mountain, TN
  2. Talon R4 LV
Todd627
Todd627
56,456
616,595
MI
Similar threads
