P500 Overheating Problem solved
Satellite
Satellite
14
47
Ky
I’m having trouble with overheating on my 2016 p500 go a ride about 5 miles or so it overheats my over flow tank is about 3/4 full i can pour it back in get the nose end up and rib it up a few times temp goes back to normal good for another few miles. Things I’ve done so far new radiator cap , thermostat, water pump, temperature sensor and pressurized the head no leaks , flush the radiator and block check all hoses blockages all clean. Any help with this would be highly appreciate.Here a little more background on this p500 trade for this it was in bad shape when I got he was non running had a heater in it before I got it this was a winter project for me removed roll bars painted the frame roll bar back in January had a bad accident working on it a chair I was using broke and cut my finger off from my first knuckle broke bone in three places 2 hour surgery truck lot stitches they was able to save my finger. around mid February before I could start working some on it again clean wash flush everything on this machine this is all the stuff I’ve done to this to get it running new stator pickup coil , gear position sensor, angle sensor, o2 sensor , rear axle seals , this machine runs like a champ and uses no oil Thank you all for helping me try to figure this thanks again
11,377
84,858
Did you bleed the air out? Also are the radiator fins clean? Only time I had overheating was a mud caked radiator. Best of luck.
5D4DBCE7 9CDB 46EB 908C F9AAE5B6CDCA
Mark in Northern Iowa
467
2,089
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa.
Post up some pics of your ride.
Here is a good thread about testing the fan circuit
And if you use the search bar at the top
500 overheating
many threads to help you.
Have a good day
Satellite
Satellite
14
47
Ky
I burp the system put in up high in the air push coolant in the over flow then the radiator goes cool burp it again and goes a few more miles and does it again thx for the quick response
Satellite
Satellite
14
47
Ky
500 overheating
Have a good day
Hook fan up straight still over burp the system to still does it thx for the quick reply
Parttime
Parttime
44
262
West Monroe La
I’m also going to go with the radiator fins are blocked. For being a 2016 and mileage is unknown to us the reader. Muddobers will build a nest anywhere. Spray the front radiator with simple green or mean green or purple power. Let it soak a hour spray it again. Let soak again. Then rinse it off real good.
Satellite
Satellite
14
47
Ky
Thanks for the reply it’s all clear got me stump what going on
Satellite
Satellite
14
47
Ky
Need pics of radiator specifically and machine -
37E410AF 9AC6 44C6 8E3E 0F462CEF4BCE 582E42EA 1CDE 44C9 A407 DED3A4D81765
Satellite
Satellite
14
47
Ky
And your 100% sure on that?
used a pressure washer on it?
weve seen this many times, comes down to a full or partial plug in spots that couldnt be easily reached.
It’s clean
thanks for posting pics but a closeup of radiator fins is more helpful - i am not convinced
-fan comes on?
-fan is blowing towards cab?
-you do see the coolant circulating with cap off?
I’ll get some pictures this evening
Satellite
Satellite
14
47
Ky
-fan comes on?
464A749E 37A5 40F4 99DD B97F38125C06 050E1795 B1FC 44CF 83A5 E7A56FB2416C E0586590 F87F 43E3 B76A 63D23AC58111
Reactions: Buggyman
DRZRon1
DRZRon1
887
2,888
did a heater get installed at some point?
agree with air - had a bunch of rzrs I put heaters in, had those front ends jacked up as high as reasonable, radiator cap off, get hot so tstat opens and fan cycles - let sit overnight, rinse and repeat - damn bleeder screw was almost impossible to get to
could see air bubbles coming to radiator fill every time until all air out
906UP
906UP
13,173
123,148
da Yoop
Air in the system.
I agree air is the issue..keep burping it slowly and it will resolve.
This ^^^^^
A cooling system isn't that complicated. If your radiator is clean, the fan is turning in the correct direction, the thermostat & wp are functioning correctly, well that's it. You say it's circulating so you don't have a hose or pipe that's collapsed. There's really nothing else. Have you tried to bleed the system at the bleed screw, #3 in the diagram that @Mudder posted?
A blown head gasket can cause pressure in the system and overcome the rad cap to push the coolant into the overflow but this usually happens before the engine temp gets hot.
