Overland picture thread. MOM#4, 2023
Tramguage1
Tramguage1
Texan
7,143
27,177
Somereset, Texas
More
20230930 075438 20230930 075428 20230930 075420 20230930 075305 20230930 075224 20230930 075320 20230929 224230 20230929 185444 20230929 121543 20230928 110124 20230927 194135 20230927 192927 20230927 163240 20230929 101335
Racerhed
Racerhed
544
5,314
Ashland OH
  2. Talon X LV
Got home about 4:30. Kicked Mike’s machine off the trailer and went to the local DIY wash. After dropping 33.00 it’s acceptably clean.
Here’s my contribution. I didn’t take that many because I suck.
71789244642  5DB4C040 7C71 4C9C A993 67D41F2FADE6 IMG 1633 IMG 1634 IMG 1637 IMG 1636 IMG 1638 IMG 1639 IMG 1642 71769827779  D363E721 3E8A 4BF1 A4D1 551264B259D0 IMG 1646 IMG 1647 IMG 1648 IMG 1649 IMG 1650 IMG 1651 IMG 1652 IMG 1653 IMG 1654 IMG 1655 IMG 1657 IMG 1658 IMG 1659 IMG 1661 IMG 1664 IMG 1662 IMG 1666 IMG 1667 IMG 1670 IMG 1669 71788594951  BE228058 31DB 496F BC5E 6C4E85CB6645 IMG 1675
5,048
22,627
I have a question about the above tip over - we had a very similar trail out here but quite a bit steeper (going uphill). The off camber to the left was about the same. By the time I realized it was too narrow to turn around, I was leaned over, hard left and expecting to drag the driver's side all the way to the top, at least 1/2 mile.
Happily, nothing dragged, much to my surprise. :oops:
The question - I put the driver's side tires in the lowest track (going the same way as in the photo) - shouldn't this driver have done that instead of putting them up on that steep wall?
Not trying to be a dik, trying to avoid doing the same thing.
They've since leveled the trail here, I just rode it Friday and wondered where the off camber went. 🤔
63,983
Usually, you want to straddle the ditch....
And I did. Almost made it and back tire slipped down.
The above pic is me backing out trying to save it.
Without rear steering, you are at the mercy of wherever it takes you.
5,048
22,627
Thx, I thought that might be what was going on. I do try to straddle most ditches but that one is extreme. I didn't think it would be possible to get the left side to ride that angle.
5,048
22,627
Another question for extreme tilts - it seems I read that the Talon will keep running at a steeper angle one direction than the other (left tilt vs right tilt). Have you experienced that and which side will run steeper?
I've seen your video when you were able to back up from tipped over to re-right yourself and was amazed that the buggy kept running when tipped over. That one was on the right side. I think that was the P1K though (it was dark, couldn't tell).
63,983
My P1k would cut off when tilted on the driver's side more.
The passenger side would have to be almost laid over to cut off.
Talon seems a little better on the drivers side.
It stayed running there for a bit here.
And yes, there have been similar situations where we were able to ride it back and recover.
Just got to get that right rear tire up.
Bcavin351
Bcavin351
Baton Rouge, LA
It doesn’t run with it upside down for sure.
JenElio
JenElio
65,018
608,651
Loxahatchee, florida
I think the video you're referring to was @Adam490's P1K5 righting itself back up, @Cyberjunk was recording him........but Adam's a one arm wonder that phucker can do stuff most can't 😂😂
NoMo!!!!
