P1000 P1000-6 Farming/Family/Hunting Rig Build
G
GetDux91
16
87
Iowa
  1. 1000 6 Crew
Initial Post
2023 Honda Pioneer 1000-6 Camo
Factory Installed : Honda Full Glass Windshield, Honda Hard Top
Dealer Purchased Accessories: Honda Rear Hard Shield, Honda Soft Door Uppers Front/Rear
Will post more photos as things are installed. Also have 2 boxes worth of electrical items from the HondaSxS store on the work bench to dive into.
Stay Safe, Have Fun!
5b434a056a08a76748eaa7d658d629a6
JenElio
JenElio
64,421
604,055
Loxahatchee, florida
Initial Post
Welcome to the club from South Florida
Nice ride 👍
G
GetDux91
16
87
Iowa
  1. 1000 6 Crew
Got the dual battery installed, following multiple threads on here nearly exact. Took some time to find mounting locations for the necessary hardware, but it all came out pretty good. Thanks again to those who contribute!
A04f9ee6cb669aabed70475e59d30011
105,538
Looks good. Nice to see you using the forums search and Much info on builds we have all done.
Reactions: ChadD and GetDux91
G
GetDux91
16
87
Iowa
  1. 1000 6 Crew
Added the TurnPro blinker/hazard/horn kit from the store. While the connections themselves were simple, I spent a lot of time finding the best routes and mounting locations to keep the install clean. Also ran two wire runs to the rear of the rig, along with two to the center portion(tucked under the passenger front seat). These will be used later, but made for an easier install while I already had the skid plate and plastics off.
I put together a short video explaining the wire routing and switch mounting locations I chose for the 1000-6. While TurnPro has a great step by step for the install, I found myself often second guessing if I was running things correctly. Hope this helps someone!
G
GetDux91
16
87
Iowa
  1. 1000 6 Crew
Quite a bit more progress recently.
-Honda Soft Upper Doors x 4
-Honda rear hard shield.
-RB3 off-road door bushings
-Installed flanged bulb seal around 3 sides of each door to lessen the gap.
-KemiMoto Wiper and Mirror
631161d97f4f7ba73574ad1aa98cf481
T
twahl
23
  1. 1000 6 Crew
Where did you find that flanged bulb seal and is it working out for you? I ordered bulb seal with the sticky back and used plastic prep but it still peeled off. Another question, how well does the oem rear panel seal up? It wasn't available when I got mine so I had to go with the super atv one. It let's in a ton of dust and cold air.
Reactions: ChadD
Similar threads
Replies
Views
1K
Replies
Views
207
BilletGarage
Replies
11
Views
752
P1K5Dave
