P1000 P1000 broken engine mounting bolts
RingMaster
RingMaster
176
710
Little Rock, Arkansas
Has anyone had the unfortunate luck to have had the two driver side engine mounting bolts break off inside the engine case? I first thought the bolts had simply loosened and fell out. But when the mud I THOUGHT was in the hole scratched shiny I realized the bad news.
There's no room to drill a hole and use an extractor due to the frame being in the way. It appears that I may have to remove the entire engine. Did anyone figure out a way to get at those two suckers without removing the engine?
I've gotten 14k wonderful miles out of this great 2016 machine. I've done all the repairs myself . . . up until now.
Thanks for any help!
RingMaster
A.k.a. Chris
208,013
RingMaster
A.k.a. Chris
Did you pull a Smitty?
TripleB
TripleB
11,706
99,395
Caryville, Tennessee
RingMaster
A.k.a. Chris
@joeymt33 @snuffnwhisky @ohanacreek
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Do a quick search on removing broken studs bolts with a stick welder.
They make a special stick that the flux protects the bolt hole threads in an engine or tranny case. You basically hold a nut over the hole and then strike and arc within the bolt hole and let the weld puddle build up even with the outer edge of the nut. When it cools, you use a wrench on the nut to unscrew the broken off bolt or stud.
This has saved many an engine removal for a broken exhaust manifold stud I bet!
39,079
I’ve had to fix a couple pioneers like this now and the best way I found is holding a nut against the engine case and filling the nut full of Weld so that it welds its self to the stud and then take it off with a socket or a wrench while it’s still hot.
After that, by some grade 12.9 socket head, studs and use those instead of the factory bolts. I can go down to the shop and check later but I’m pretty sure it’s metric 10 with a 1.25 thread pitch.
Vikes79
Vikes79
SKOL!
10,877
105,534
South Dakota
  2. Talon X4 LV
105,366
@RingMaster
@joeymt33 knows this issue well and will take care of you here.
Post some pics of this broken bolt tho. Deff worth seeing
RingMaster
RingMaster
176
710
Sorry to hear about this.
Can you share some pictures? We might be able to come up with some solutions that you may not think of.
It's the bolts pointed as #1 here:
20230710 180941
I have already removed the bracket in these photos
20230710 1812032
This is the rear most bolt hole
20230710 1812152
The first ont is the same. I couldn't get a good pic of it.
RingMaster
RingMaster
176
710
RingMaster
RingMaster
176
710
That sounds like a great idea. However it requires a stick welder and the skill to use it. I have neither. Maybe I'll try to find somebody else that can do that for me thanks for the pointer.
39,079
This is a slow process it’s not that you broke it with only doing one thing. The way that these bolts are rocked back-and-forth, they eventually fatigue and fail.
Yours looks like a prime candidate to hold a nut up there and you can use something as simple as a flux core welder.
39,079
I wish I had a better picture of the motor mounts that I was making long before Hess, or any of these other companies were making them for the talons and other vehicles. I think so far I’ve put one on Adams, Plumber’s and triple B and another friend’s vehicle as well.
4889801e3d33c968d4757231e152f5bc
You can see the grade 12.9 socket head bolts here. And what’s not pictured very well, is the extra metal, I welded to the stock mount to take it up high enough to use some different bolt hole locations.
Maybe #Adam490 or #plumber32 has some pictures of theirs. We built and installed theirs before the bolts broke as a preventative measure.
39,079
RingMaster
A.k.a. Chris
Do you have any reason to drive to North Alabama? If so, bring the Honda with you and I’ll get it fixed up.
If not, give me about a week and I’ll make another motor mount and mail it to you, but you’ll have to get the broken stud out yourself.
39,079
Whatever you do, do not try to use one of the damaged bolt extractors. After you drill out the bolt and use that tool, it will stretch the soft factory bolts and make it so tight. It will not come out. Ask me how I know……
621db8c281d04053651cd8d2c9ba6f5d
bumperm
bumperm
1,848
6,646
Gardnerville, NV
@joeymt33 Just a WAG (I haven't looked at the mounts in question. Do you think loose bolts, perhaps due to stretching, could be part of the failure mode? This might allow the motor to put additional stress on the fasteners? Would checking the bolt torque occasionally be a good idea? Or, absent the your reinforcement doubler, replacing the bolts with higher strength ones?
If you get the chance, please post a better picture of what you did. Thanks!
