P1000 P1K5Dave's 1000-5 Build
P1K5Dave
P1K5Dave
2,180
8,162
Petoskey, MI
I made the mistake of checking the damn spark arrestor again a while ago, now I'm down to 1 of 3 bolts holding the exhaust tip on there.
One was broke off when I bought the machine. I religiously applied anti-seize to the other two - but this time, one twisted off. Those bolts are so soft you don't even know you're twisting it.
So today I went to look at what I need to do to get those two broken bolts out of there, and thought "what if I just bought a new muffler?"
And HOLY SH*T - I looked that thing up and it's $590! Damn...
mlynch001
mlynch001
193
879
Dardanelle, AR
The Catalytic converter adds a lot to the price of a simple muffler. Have you looked at the possibility of using RivetNuts? That is what I was thinking about after my last "go-around" with mine. I have not broken a bolt, but I am just fortunate that mine came out OK.
Reactions: JenElio
P1K5Dave
P1K5Dave
2,180
8,162
Petoskey, MI
That's a possibility, thanks @mlynch001.
I just bought a new rivnut tool and a bunch of them to go with it, so a possible use for them. I figured this would be a good place to try the "weld a nut on it" approach and see if it works.
I can tell you what I'm not going to do: "Easy out." In quotations because they ain't easy, and nothing comes out. F those things.
JenElio
JenElio
65,125
609,353
Loxahatchee, florida
Spin the tip a tad and run some self tappers in that mofo. I wouldn't even bother spending time taking the old out, grind them down if need be and be done 🤷‍♂️
My unsolicited 2 cents 😂
  • Haha
Reactions: Coeus and NTCPrezJB
mlynch001
mlynch001
193
879
Dardanelle, AR
Weld a Nut does work, if you are careful. One thing I learned was to heat the local area "dull red", then "shock" it by rapid cooling, THEN after it cools, weld the nut on and attempt removal. This is a trick that my fabricator dad taught me over 50 years ago. I have used it many times. I have used an EZ out with success, but I have also seen more that failed than those that worked.
Reactions: JenElio
P1K5Dave
P1K5Dave
2,180
8,162
Petoskey, MI
I'm assuming there's a little more structure in the muffler at the points the bolts went into, aren't there? Or, if it's a solid ring, your idea may be a winner...
Reactions: JenElio
JenElio
JenElio
65,125
609,353
That area where the tip is bolted on is doubled up from the inside. It's got like a 2" reinforcement flange from the inside. There's plenty of metal to self tap into. I ended up cutting the ends of my muffler in search of that stupid annoying rattling sound, that's how I know....🙄
Reactions: TripleB
mlynch001
mlynch001
193
879
Dardanelle, AR
If you cut off both ends of the muffler, can you tell me what is on the other end of the muffler? The end without the outlet.
Reactions: JenElio
P1K5Dave
P1K5Dave
2,180
8,162
Petoskey, MI
I think there may have been a thread with pics, wasn't there @JenElio ? If so, I'd like to see it again as well...
JenElio
JenElio
65,125
609,353
There's nothing at the other end. And believe it or not I didn't think to take any pics of when I actually opened both ends. I actually ended up swapping the ends on the muffler........ exhaust tip is on the driver side now......🤷‍♂️ I was bored 😂.
Here's a crude sketch of what I noticed inside.
IMG 20230921 124659773
By moving the tip over to the opposite side it does sound just a bit 🤏 louder but nothing crazy. I think it'll flow a little better too especially in addition to having the cat removed. Haven't noticed any loss of back pressure either sooooo 🤷‍♂️
Reactions: mlynch001
mlynch001
mlynch001
193
879
Dardanelle, AR
Perfect, Thank You!
Reactions: JenElio
Similar threads
