P500 P5 with a 680 engine.
CURTK
35
Central MN
I recently sold my '07 Rincon to ride with friend(s) more comfortably on a P5 so I can drive it on the state trails with the 50" maximum width restrictions. I can't help but think how REALLY nice the P5 would be if it had that engine and transmission. Three speed Hydro or if they made a 5 speed hydro with auto and paddle shift. I think that would have the best of both worlds, great engine/tranny and drive it on state trails.
Anyone else have the same feelings? Any chance Honda would make a rig like this down the road?
Reactions: swsebek
500oneer
500oneer
15,000 mile club
419
1,045
Central PA
If Honda does that they need to upgrade the suspension. I am satisfied with the power but give me better shocks.
64,288
Yes, I would be all over a 55" machine with the Rincon 3 speed or new Rubicon DCT.
Both already have the layout for a paddle shift system.
If this happened... there would be one in my garage ASAP. I think that would be a home run for just under 10K.
Reactions: swsebek and JTW
RydeAK
RydeAK
103
296
Alaska
Doesn't the P700 have the 680 motor and the 3-speed?...
But yea, 55in wide with long travel suspension and the 680 motor. And under 1200 lbs. Sounds fun! I'd prefer 5 or 6 gears tho instead of 3.
Reactions: JTW
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
You guys keep saying 55". The restrictions around here are 50" wide and 1" lugs. Is that not the case around the country?
CURTK
35
Central MN
It's the 50" restriction that's the problem. Up here in MN we have hundreds of miles of state trails to drive on but you have the width rule.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,771
183,175
Grand Junction, CO
The Rincon Engine would be nice if they could make it fit but not with the auto tranny. I had a Rincon and really liked it except there was no engine braking and here in Colorado I was having to stand on the brakes on long down hills more than I wanted. Several times I would stop just to let the brake cool. The tranny using electric shift was fun except on steep hills.
Reactions: WillB
CURTK
35
Central MN
The Rincon is 38.5 or 39 hp and the P5 is 28.5.
To be honest, I miss the smoothness of the shifting. I don't recall the engine braking issue being a problem but then we don't have the terrain you have out west.
RydeAK
RydeAK
103
296
Alaska
We have no such restrictions in Alaska. They might restrict the type of vehicle in some areas but that's about it. I went with the P500 partly because of its narrow stance and light weight, but I would not mind at all if it was a little wider.
RydeAK
RydeAK
103
296
Alaska
The P700 says 36.4. 7 more horsepower may not seem like a lot but it is a 25% increase. I'm sure it would be very noticeable.
On another note, I thought the following was interesting. Surely the P700 feels faster than the P500 right?
Power to Weight Ratio:
2016 Honda Pioneer 500 Horsepower – 28.7 HP
Pioneer 500 Horsepower to Weight Ratio – ( 28.7 HP / 1,010 lb ) = .028 horsepower per pound
2016 Honda Pioneer 700 Horsepower – 36.4 HP
Pioneer 700 Horsepower to Weight Ratio – ( 36.4 HP / 1,261 lb ) = .029 horsepower per pound
The Yamaha Viking has 46.9 hp and is insanely reliable. WTH honda?
Reactions: Gator
pFive
pFive
670
1,267
Greenwood IN
Torque and gearing, the 500 has both. I have not seen a Viking on the trail, but when I watch the R spec on youtube it always sounds like an RZR 800 in high gear and seems to bog down.
RydeAK
RydeAK
103
296
Alaska
I've driven a Viking a bunch. They are really loud in the cab, but the suspension and ride is plush and it has more legroom than anything else I've seen. But the footprint is giagantic
