P500 P500 Fuel Pump Replacement
KyGal83
KyGal83
7,701
77,137
Kentucky
Impact screwdriver…
I didn’t pay attention to the listing to see if it had JIS or “Phillips” technically I think it’s supposed to be called “Robertson” bits with this particular one but that is the basic tool I was suggesting. JIS “Phillip” bits have more sharp angles on them whereas the Robertson version are more rounded.
If memory serves anyway. I’m sure Mr Go Ogle or someone that cares more than me could get you the absolute correct answer. Just know the Honda fasteners are JIS and will be less likely to strip if you use a JIS bit on them.
Got! Just ordered one.
KyGal83
KyGal83
7,701
77,137
Kentucky
Step one: Gather up all the tools and research to remove and install. - In process
Gonna have to put this on hold. My dryer heating element went out, Replacing that will take present over the 500.
NTCPrezJB
NTCPrezJB
President of #NTC
100,804
900,538
Canton, OH
Stupid dryers!!!
Reactions: Coeus and Mudder
Backwoods
Backwoods
32,349
332,034
Douglasville ga
Your in Kentucky just use a clothes line. Modern solutions for modern problems 🤣🤣🤣🤣🤣
Mudder
Mudder
NTC Ambassador of Walls
11,326
84,200
Hope your dryer repair is not a PITA like my LG. I had to disassemble panels and electrical connections from top down and remove the drum for access. Glad I took pics of each step to help reassembly. Good luck.
KyGal83
KyGal83
7,701
77,137
Kentucky
Absolutely a PITA… but the alternative has me removing the exterior door, my bedroom frame, and closet door… then dragging it out of my RV to take it to someone to repair or replace it completely. I will figure it out. Found a couple of somewhat helpful / not helpful videos on YouTube.
Just more stress I do not need. But that is life..
KyGal83
KyGal83
7,701
77,137
Kentucky
Thank you @NTCPrezJB… this arrived. I had to Google and YouTube how to use it. It is a handy tool!
Dryer heating element arrived also… albeit the wrong one.. so repair guy is coming to take a look and find the right one. He will order and I will install.
Working on clearing a space in my storage unit so I have somewhere indoors to replace the pump. Stay tuned.. hopefully soon.
IMG 6463
NTCPrezJB
NTCPrezJB
President of #NTC
100,804
900,538
Canton, OH
Not a tool I use often but it is worth every penny paid for it when I do use it.
Nomojic
NTCPrezJB
NTCPrezJB
President of #NTC
100,804
900,538
Canton, OH
Also…stupid dryers!
NTCPrezJB
NTCPrezJB
President of #NTC
100,804
900,538
Canton, OH
Thanks for recommending.. prolly not something I will use often either, but definitely something worth having on hand. And a Black Friday deal of $15 shipped!
Yeah most of the Honda screws have blue loctite on them. That tool will help you not strip out those screw heads. As soon as they break loose go back to the standard screwdriver or a ratcheting screwdriver.
906UP
906UP
13,052
121,736
da Yoop
Solid advice.....This is why he's da Prez
