P500 P500 Inferno heater instal- lessons learned?
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
No part number, I went to NAPA and we took a look at what radiator hised they happened to have with a 90 degree angle.
LandofCheese
LandofCheese
44
416
53
The sxs is 2 hours away and the nearest auto parts from there is an hour so i'm trying to bring what i need up with me. does an I/D of 5/8ths sound right?
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
I think so., 5/8” is a standard radiator hose size. Check the size of the hose that came with it.
Here’s one on amazon.
Dayco 80402 90-Degree 5/8” Diameter Molded Coolant/Heater Hose with 18” Total Length
The other thing I did was to seal up the air tubing on both ends where it meets the ducts in the dash and on the heater itself. I used the aluminum high temp foul for chimneys because I had a big roll left over, and the stuff sticks great. Duct tape would also work.
Reactions: Buckaroo41
Buckaroo41
Buckaroo41
37
150
South of Heaven West of Hell
How has the heater been working so far? Worth the time and money invested?
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
Andolutely. Together with finding and blocking as many cold air infiltration points, it takes about 10 minutes for the P5’s engine to get warm enough for the engine thermostat to open and get heat coming out.
I still wear winter clothes but find I take off my cap and gloves and unzip my jacket. I’m comfortable riding. I’ve not tried unplugging the fan or blocking the radiator with cardboard- I’m not looking to ride at sub freezing temps with a T shirt.
I adjusted the reverse lockout cable from the under dash pull down years ago. That area was a major source of cold air entering the cab. I just covered it with black Gorilla duct tape. No points for pretty when you’re cold!
I have to think about how I could use cab air as the heater input instead of continually sucking in outside cold air.
