Talon Paul's Talon R
PS3471
PS3471
This will cover my progress as my R evolves.
My situation as I write this: Ive had my R for a week. 66 miles, not nearly enough! Currently ive made 2 changes since bringing it home. 1 : Removed door nets 2 : I rotated the spark arrestor clockwise 1 hole. The reason is to help push sound and exhaust gas back behind the machine.
Future plans include tires windshield winch bumpers tree kickers...ect ect. My parts list is way bigger than my wallet so things will progress slow.
15607006475667844588859934061436
15607007208591548702785372128988
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Future plans include tires windshield winch bumpers tree kickers...ect ect. My parts list is way bigger than my wallet so things will progress slow.View attachment 135990 View attachment 135991
Good looking rig ! Welcome to site good to see another Missouri guy on here ,what part ?
Reactions: Mopower58
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Welcome from SE Missouri.....
You may consider drilling some new holes in the tip...the way you have it now looks like a good way to hold water
PS3471
PS3471
Some goodies came in today! Im pretty excited about this one.... the Super ATV Talon Tailgate. Install was super easy, remove 4 allen head bolts. Set tailgate into position. Install supplied bolts. Tailgate is solid and built well. It did seem slightly narrow.....about .5 inch. But once all the bolts were tight it drew out to mating surfaces just fine. It has a few loops for tie downs in the corners. I may add a screen around the inside to keep smaller things contained.....but its way better than a wide open spot.
20190619 175627 20190619 175642 20190619 175632
Vondy
Vondy
1,399
8,948
Houston,OH
  1. Talon X4
View attachment 137002 View attachment 137003 View attachment 137004
Do you think it's sturdy enough to hold a 2 gal rotopax or a spare tire?
Reactions: BWAF
PS3471
PS3471
Definitely ready for a rotopack or jerrycan. The sheet metal looks to thin for a tire to be bouncing around on it. The frame will support it, so id say if you welded a few heavy uprights in it it would work for a spare
Reactions: BWAF and Vondy
PS3471
PS3471
I decided to go with a 1/2 windshield. I dont want to feel like an ant under a magnifying glass, but some break from the wind is nice. I went with the Super ATV 1/2 windshield. It was waklet friendly. Install was a breeze! Came with plenty of weatherstrip, fit was good and the mounting tab layout was spot on. 2 plastic and velcro clips secure the wind screen, while at the same time cover up the roll cage bungs. Can be put on or taken off in minutes. Im 6'2, and it pushes the wind up far enough i can feel it at top of my hat. No more turning my hat backwards or having it blow off. Tested to 65 mph. Downside is that its lexan....prone to scuff and scratches. Ill be on the lookout for some kind of coating. Over all very pleased with its performance.
20190619 174406 20190619 174411
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
That looks sweet
BWAF
BWAF
8,857
42,437
Carthage MO
View attachment 137235 View attachment 137240
Was it hardcoat half window? My 2 pics Honda has done well with the brush I run it thru just don't rub it dry
PS3471
PS3471
It was the half windshield from superatv.com. or did i missunderstand something?
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Did they list it as hard coated or scratch resistant
PS3471
PS3471
Standard .250 clear polycarbonate. Other option is tinted poly, bit it was more cash
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Just water to clean maybe get squeegee it'll last a long time
